DELL Wyse 5070 BIOS
  • nikal
    • Jul 2023
    • 36
    • Greece
    DELL Wyse 5070 BIOS
    Hi!
    I kindly need your help with a DELL Wyse 5070 thin client which has locked BIOS settings (I want to change the boot order but I have to provide a password first). Is it possible for someone here to help me ?
    I am attaching the original bios dump of the machine in question.
    Service Tag: 5X1ZQL3
    I would really appreciate any help.
    Thanks in advance!​
    • 21100
    Thread moved to desktop PC bios requests.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11863
      Originally posted by nikal
      Hi!
      Thanks in advance!
      Wyse 5070 Thin Client
      • nikal
        • Jul 2023
        • 36
        • Greece
        hoaca388 Thank you very much for the help.
        I will test this BIOS file and get back to you with results the soonest possible.
        Kind Regards!
        • nikal
          • Jul 2023
          • 36
          • Greece
          Hi hoaca388
          Just programmed the flash and soldered it to the motherboard but unfortunately it doesn't seem to work. I get the following error code.
          Two blinks followed by a short pause, one blink, long pause, then repeats. Which translates to "bad motherboard". If I flash back the original BIOS it works but BIOS settings are locked with Admin password.
          Thanks for your try though and If you have any idea what's wrong please post a new BIOS files.
          Kind Regards
          • hoaca388
            Badcaps
            • Jan 2022
            • 11863
            Try change bios new chip .
            • nikal
              • Jul 2023
              • 36
              • Greece
              Hi again,
              tried with another SPI flash and it's the same. The same error code. The original BIOS works though.
              Kind Regards
                • 21100
                Hi!
                https://www.dell.com/support/manuals...0b3&lang=en-us
                • Administrators—The default user name is Admin and the default case-sensitive password is DellCCCvdi.
                • Users—The default user name is User and default case-sensitive password is DellCCCvdi.
                • nikal
                  • Jul 2023
                  • 36
                  • Greece
                  SMDFlea Thanks for the info. I'll try it and let you know.
                  Kind Regards
                  • nikal
                    • Jul 2023
                    • 36
                    • Greece
                    SMDFlea hoaca388
                    Unfortunately, the password doesn't work for this thin client. This machine found in a recycling bin and turned out to be an HSBC property (based on the logos during the boot) so for sure they would never use this well known public password for the BIOS. If someone can help to unlock the BIOS of this machine would be wonderful as it can become a powerful home Linux router. Right now it boots only from the on board soldered emmc or the ethernet but it also has m.2 slots for ssd drives. All the BIOS options are locked and can't change the boot order or the boot devices.
                    • mily.gawel
                      • Aug 2018
                      • 42
                      • Polska
                      can anyone help me fix my bios. An error pops up every time "Fatal :smbiosGetstruct() SMBIOS structure 0 hasa lenght 0" when i try enter to bios. S/N 90T8KT2
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11863
                        Service Tag: 90T8KT2​
                        • mily.gawel
                          • Aug 2018
                          • 42
                          • Polska
                          Power button blink 4/1 orange only now.
                            • 21100
                            Try only 1 stick of RAM ,or different RAM. The issue could be RAM compatibility https://www.reddit.com/r/HomeServer/...0_ram_upgrade/
                            • mily.gawel
                              • Aug 2018
                              • 42
                              • Polska
                              Men you are amazing it really works. Thaknks soo much
                              • flikz
                                • Mar 2025
                                • 8
                                • lebanon
                                Hello everyone, first i want to thank everyone who's behind this great forum <3
                                i have multiple dell wyse 5070 thin clients, that was shipped with hp 90w adapters.. sadly it wont work unless its the dell brick with the integrated ic that has the 90w info on it... hp adapters obviously got me stuck with 1.5ghz and limited power usage
                                i dumped the wyse bios using my programmer, can some1 help me disable that powerlimit please ?
                                  • 21100
                                  Thread merged. It is something that cannot be changed in the bios, just use original dell adapters.
                                  • flikz
                                    • Mar 2025
                                    • 8
                                    • lebanon
                                    SMDFlea thank u sir, but how did https://github.com/KCORES/KCORES-5070 this guy do it ?
                                      • 21100
                                      I don`t know, but i translated part of the readme -
                                      The BIOS file is in the BIOS folder. Flashing it can directly solve the power identification problem and improve performance. However, DELL protection does not allow soft flashing of BIOS. The CH341A programmer must be used to directly flash the BIOS chip. The BIOS file was modified by @Naivekun. The main functions are: Delete power detection, and it can be used as long as it is plugged in Increase PL1 turbo frequency limit, and the performance is on par with J5040 Increase CPU main frequency (not effective) ⚠Note: Flashing BIOS may cause the motherboard serial number and integrated network card MAC address to change Power supply Voltage range According to the test, Wyse5070 allows a wide voltage range of 9~20V. If using a battery, a 4S lithium battery can be directly passed through to avoid voltage regulation and improve battery utilization Power identification It is recommended to use a DELL power adapter, and it is best to buy a model marked with 120W information flashed in. To prevent the motherboard from identifying the power supply as insufficient and prohibiting turbo frequency when plugged into a fat machine It is not recommended to use the original 19V laptop power supply, because the subsequent use of the PCIe adapter card requires 12V power supply​
                                      • nikal
                                        • Jul 2023
                                        • 36
                                        • Greece
                                        You know something ? Your link helped me to unlock the BIOS, it solved my original problem the reason I did this post. I decided to give a try to this BIOS because I was sure it was unlocked and made to be flashed in any Wyse 5070. I tried but the first time it didn't boot but I had no error code so I decided to clean the IntelME region and re-flash it. The machine booted and the BIOS is now fully unlocked
                                        Thanks once more and SMDFlea who merged your post with mine.
                                        Kind Regards
                                        Nikolas
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • noTurner
                                          Dell Wyse 5070 BIOS update not possible
                                          by noTurner
                                          Hi there! As stated in the title of the thread, one of our problematic Dell Wyse 5070 does not update its BIOS. Is anyone here able to help me by cleaning the BIOS regions and possibly updating the BIOS to ver. 1.20.0?
                                          The service tag is FMWF5P2.
                                          I got a dump of its original BIOS with version 1.1.3.
                                          Thanks!...
                                          05-11-2023, 12:49 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
