Change BIOS serial number for HP ProDesk 400 G6 Mini PC
  • masvmasv
    • Jun 2023
    • 5
    • Brazil
    Hi!
    There is a way to change a BIOS serial number for the computer:
    HP ProDesk 400 G6 Mini PC ?
    Thank you
  • volinakis
    • Jan 2021
    • 2733
    • N/A
    Re: Change BIOS serial number for HP ProDesk 400 G6 Mini PC
    Originally posted by masvmasv
    Hi!
    Thank you
    try with WNDMIFIT. https://www.badcaps.net/forum/showthread.php?t=69204
    • masvmasv
      • Jun 2023
      • 5
      • Brazil
      Hi!
      Thank you for your answer.
      I try use the version 2.13, but dont work, the message error is: "This system board is not suported. Will not be able to set BIOS settings".
      There is a new DMI Tool version after 2.13 version?
      Thank you
      • masvmasv
        • Jun 2023
        • 5
        • Brazil
        I found version 2.14, but the problam is the same. I try use the "BiosConfigUtility64.exe" with /get and /set parameters. If I try change the serial number inside generated file, they show the message: "Serial number is read-only", and not allow change.
        There is another way? Thank you
        • volinakis
          • Jan 2021
          • 2733
          • N/A
          another way is to put motherboard in MPM mode but you have to read your bios and write it with a programmer.
          • masvmasv
            • Jun 2023
            • 5
            • Brazil
            And how can I put motherboard in MPM mode ?
            • peste
              • Dec 2016
              • 12835
              • ROMANIA
              maybe this will help you..
              https://www.youtube.com/watch?v=9T57ktw8n3Y
              • masvmasv
                • Jun 2023
                • 5
                • Brazil
                I try the steps from video and wont work :-(
                The message error is: "MPM access denied"
                • OKRPKCOMP
                  • Dec 2020
                  • 429
                  • PAKISTAN
                  TRY
                  https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                  • masvmasv
                    • Jun 2023
                    • 5
                    • Brazil
                    Originally posted by OKRPKCOMP
                    Hi! Dont work too, the same result: Access denied.
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • Friend33
                      Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
                      by Friend33
                      I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
                      06-16-2024, 03:13 PM
                    • beBoss
                      HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                      by beBoss
                      as noobie to this please excuse my lack of experience.
                      I am trying to remove a BIOS password from this machine:
                      but so far I still have no success.
                      I bought CH341 programmer and decided to give it a try.
                      The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                      I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                      05-30-2024, 12:48 PM
                    • TecnicaNTT
                      Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                      by TecnicaNTT
                      I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                      My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                      I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                      I am now asking here for help if anyone knows how to do this in...
                      09-20-2024, 08:10 AM
                    • xxxchudyxxx
                      How to transfer serial number and DMI data from bad HP BIOS to good one?
                      by xxxchudyxxx
                      i have a corrupted BIOS file from a laptop, but i need to recover the serial number and DMI info (like product name, UUID, etc.). I also have a good BIOS dump from the same model.
                      Is there a simple way to copy the DMI data from the bad file to the good one?
                      HP 650 G3
                      Thanks!...
                      06-24-2025, 06:28 AM
