How to transfer serial number and DMI data from bad HP BIOS to good one?
  • xxxchudyxxx
    • Jan 2020
    • Polska
    i have a corrupted BIOS file from a laptop, but i need to recover the serial number and DMI info (like product name, UUID, etc.). I also have a good BIOS dump from the same model.
    Is there a simple way to copy the DMI data from the bad file to the good one?
    HP 650 G3
    Thanks!
  • volinakis
    • Jan 2021
    • 2873
    • N/A
    HP 650 G3
    Thanks!
    use Bios Configuration Utility (BCU). install it and use it under cmd as Admin. use cmd line "biosconfigutility /get:1.txt" (or whatever you want to name it). Open 1.txt with text editor and change serial, sku buildid, fearure byte, CT and mac adress with one from old bios. You can find serial, sku buildid, fearure byte going to "partsurfer.hp.com" and type serial from old bios (5CG7372HL5)
    Serial Number : 5CG7372HL5
    Product Number : Z2W51EA
    Description : HP ProBook 650 G3
    BuildID: 16WWCLCT601#SABD#DABD
    Feature Byte: 3Q3X476J6S6Z6b7H7M7Q7W7m7saBaEapaqauawbhdQdUdpdqfXgd.eT
    CT and Mac Adress you'll find on a label from faulty motherboard. CT is PGDQK00WB911KK
    Modify 1.txt with these values, save it as "2.txt" in Documents folder then move it to BCU folder (it won't let you to save in BCU folder). Then use cmd line "biosconfigutility /set:2.txt". You can do this with BCU if you don't have password on bios.
    • xxxchudyxxx
      • Jan 2020
      • Polska
      I tried do that, but I have MPM locked
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • salim5566
        loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
        by salim5566
        Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
        06-26-2025, 03:25 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Friend33
        Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
        by Friend33
        I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
        06-16-2024, 03:13 PM
      • TraJikar Mac
        [HELP] G712LWS BIOS capsule
        by TraJikar Mac
        I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
        The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
        You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
        Also, I uploaded a backup file for the bios that I extracted by using CH341A...
        06-11-2025, 01:35 PM
