Dell 9020 AIO ME Problem.
  • ASB
    • Dec 2020
    • 133
    • Pakistan
    I have a dell 9020 all in one with corrupt me region (it turns on and immediately shuts down within a second repeating the sequence). I tried 3 different ok bios but they all give 3-7 orange led blink after some time. Caps lock/ Num lock keys show display on keyboard. According to dell website, 3-7 indicates me error. I tried to clean the original bios with FIT but both V9 & V10 give errors when I try to open the file. Please help to clean me region of original bios replacing it with same version. Thanks.
  • DoOm86
    • Nov 2022
    • 42
    • italia
    Re: Dell 9020 AIO ME Problem.
    Hello. I have never worked before on the bios, besides flashing it again like you did, I have not much to offer but a link of a guy who made a tutorial about this and I'll try it out when I have a bit of free time.
    Hoping to help you and not breaking any rule giving you a link to another site.
    https://forum.sorinelectronics.com/i...sg1242#msg1242
    Hope you can solve it
      • 20311
      How to clean ME/TXE region -> https://www.badcaps.net/forum/showpo...41&postcount=3
      Do not use use Intel ME/TXE Injector/Easy Clean ME or similar tools: they do not retain the manufacturer's configuration and can cause subsequent problems.
        • 20311
        Both files have to be joined together before it will open with FIT 9.1 .FIT 10 will not work,its only for ME 10 firmware.
        Try these.
        • ASB
          • Dec 2020
          • 133
          • Pakistan
          Thanks for ur help.
          • ASB
            • Dec 2020
            • 133
            • Pakistan
            Try these.
            Dear SMDFlea, Thank you so much for your help. With this bios, pc would continuously turn on and then turn off after 5 seconds with the ram installed. I then shorted the service mode jumper and pc came back to life. This trick (service mode jumper) didn't work with other bios. It just requires F1 key during boot and after that everything is fine.
            • toti24
              (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
              by toti24
              dell precision m4600 laptop
              i7 2760qm
              8gb ram 750gb HDD
              intel hd 3000 integraded and nvidia quadro 2000m
              pleasea bear with me english isnt my language and ill try to be as clear as possible
              note i live in mexico in a very small town..
              thank you.
              laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
              the brick happened when i was installing win 10 using usb.
              used rufus and officia microsoft.iso
              it finished copying files from usb...
              03-06-2022, 08:39 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • jhanra
              by jhanra
              in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
              11-02-2024, 04:19 AM
            • mrrubik
              Dell Optiplex 7010 micro bad BIOS flash?
              by mrrubik
              Hi folks,
              I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
              After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
              Steps I took:
              1. Read BIOS with CH341a, verified hash twice
              2. Patched
              12-23-2024, 04:11 PM
