Vega 64 - missing PX_EN
  • gurj1979
    • 186
    Hi guys,
    So for the fan to turn on and give 5v at the pin, it needs PX_EN to turn the controller on. The GPU generates this signal and sadly it is showing as 0v.
    The card shows display fine and runs as normal, but the fan isn't kicking in due to missing PX_EN signal.
    Any pointers and fixes ?
  • Prott
    • May 2022
    • 154
    • Czechia
    Re: Vega 64 - missing PX_EN
    if I understand it correctly - if the card runs fine it definitely should have a PX_EN signal from the GPU. Without it it wouldn't run at all cause this signal does bunch of other important stuff.
    Try finding out where it gets lost. If you are measuring it on the leg of an IC, for example, try to check if the leg has a good connection with the pad.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      what about resistance to gnd on that pin?
      • gurj1979
        • 186
        Yep. Resistance is 1.2 Mohm on both sides of resistor at the GPU side. So resistor has a value of zero ohms (not checked the actual value in schematics because I had to shoot off to work).
        • gurj1979
          • 186
          I've just measured the value of R109. It is 1K, same as schematics show.
          What next? Possibly dead PX_EN or reball ?
          • Prott
            • May 2022
            • 154
            • Czechia
            If there would be no PX_EN from the core the card wouldn't work at all.
            • gurj1979
              • 186
              I've had the card enter Windows with drivers. But PX_EN is not turning on and fan ain't spinning because of this.
              • Prott
                • May 2022
                • 154
                • Czechia
                Ok, I went through the schematic and correct me if I am wrong, but it looks like PX_EN actually has to be low during normal operation. If it's high it pulls down the REG_GRP_A_PWRGD which in turn disables the buck converter for the +VPP.
                That would solve the issue of the card working even though PX_EN is low.
                • gurj1979
                  • 186
                  Thanks Prott. But how does that explain the fan never kicking in, and the GPU overheats and forces machine to shut down. The heatsink become mega hot.
                  • Prott
                    • May 2022
                    • 154
                    • Czechia
                    I am checking the circuit.
                    So, the problem is that the fan never gets 12v? Can you measure the pins on the fan header?
                    Also, did you check the 0 ohm resistors for the fan? And lastly... is the fan motor working? :-)
                    I don't think PX_EN is the issue.
                    • gurj1979
                      • 186
                      I've uploaded 2 pics. One of them showing display output. PX_EN still missing but I have 3v at Q1032 pin 3. Can't make sense of this one.
                      • gurj1979
                        • 186
                        I've tried 2 fans. Original and eBay because I had doubt at the start.
                        Pin 1 = GND
                        Pin 2 = 0.035v
                        Pin 3 = 3.9v
                        Pin 4 = 0.082v
                        Forgot to mention LED light is RED at D4002
                        • Prott
                          • May 2022
                          • 154
                          • Czechia
                          That seems like normal behaviour. PX_EN, when high, pulls REG_GRP_A_PWRGD low through Q1032.
                          REG_GRP_A_PWRGD itself is powered by 5V through a voltage divider and a 0 ohm resistor.
                          • Prott
                            • May 2022
                            • 154
                            • Czechia
                            I would check R240 (should be 20k) and R213 (should be 0 ohm). Also try checking resistance between the second pin of the fan header (should be 12V ? ) and ground. Also the same pin and 12 V. On my working VEGA both of those are in the range of 10+ kOhm and rising.
                            • gurj1979
                              • 186
                              R240 = 20k.
                              R213 = no component there 4.5K.
                              Fan connector voltages listed in above reply.
                              • gurj1979
                                • 186
                                I just noticed U500 had some dodgy soldering from pin 1 to pin 14. Reflowed it, now it wont turn on. 12v & 3v still around the board, but none of the MOSFETs will turn on.
                                Either I've just killed U500, or it's not getting correct data from the components connected pins 1-14.
                                • Prott
                                  • May 2022
                                  • 154
                                  • Czechia
                                  Hard to say - I only have a schematic for Strix, which is slightly different. Though I am surprised there's no 12 V for the fan as that pin should be pretty much connected straight through to the 12 V bus.
                                  1. The resistor on R213 was never there or is it physically knocked off / blown off?
                                  2. Next thing to check is the Q211 mosfet. It should have 12 V on the second leg and positive voltage on the first leg.
                                  3. If there's 12 volts but no voltage on the base (1st leg) try checking Q212. Is there any voltage on the leg no. 5?
                                  • Prott
                                    • May 2022
                                    • 154
                                    • Czechia
                                    Check for shorts, mainly on 5V. Short on 5V would not show up outside of the card.
                                    • gurj1979
                                      • 186
                                      Thanks for the tip. I'll check another time, busy with other jobs now
                                      • Prott
                                        • May 2022
                                        • 154
                                        • Czechia
                                        To make it easier - check the back voltage regulator (under the U500). It's upmost right leg (closest to the HDMI ports) should have a resistance to ground in the range of kOhms.
                                        By the way, I confirmed that on my working Vega the PX_EN is indeed low while the card is in operation.
                                        EDIT: Could you please help me and point me to the direction of the 1k R109 resistor? I need to troubleshoot another Vega card.
                                          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                                          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                                          10-01-2024, 01:07 PM
                                        • gurj1979
                                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                          by gurj1979
                                          Hey guys.
                                          Need help with this one.
                                          Fan not spinning due to missing PWN Fan signal.
                                          Also 5 seconds from powering up it freezes, unless in BIOS.
                                          But as soon as Windows starts to load, it will freeze.
                                          CPU is COLD / Room temp when it freezes.
                                          I've replaced the CPU, same problem.
                                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                          Replaced fan - same problem.
                                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                          08-19-2024, 05:22 PM
                                        • Fernon@Repair
                                          MSI mpg b560m bazooka motherboard RSMRST# signal missing
                                          by Fernon@Repair
                                          I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                                          My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                                          VCCRTC ok
                                          RTCRST# ok
                                          ATX_5VSB ok
                                          SIO_3VA ok
                                          3VDSW ok
                                          DPWROK ok
                                          SLP_SUS# ok
                                          VSB_ENABLE# ok
                                          5VDUAL ok
                                          3VSB showing 4.17V
                                          PCH_1P8_VSB ok
                                          PCH_VCCIN_AUX ok
                                          RSMRST# No voltage
                                          this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                                          06-03-2025, 10:49 AM
                                        • mohamed mm
                                          sony vaio mbx-247, missing S5_ON signal
                                          by mohamed mm
                                          Hi everyone, I hope you are having a good day.
                                          I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
                                          The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
                                          so I checked.
                                          pu9:
                                          Vin: 19v
                                          Ldo: 4.89v
                                          Ref:1.99v
                                          Vcc: 4.89v
                                          Vdd: 4.89v
                                          output
                                          3.3v pcu.
                                          EN2: 4.89v
                                          but No
                                          01-19-2023, 05:17 AM
                                        • madura2010
                                          LA-G07FP ACIN signal missing
                                          by madura2010
                                          10th generation hp laptop(LA-G07FP motherboard) missing ACIN signal.charger light not blow.when pressing power button, only 3 blinks display on dc adapter bulb(only once).but not turning on.original hp charger attached.charging port perfect.
                                          19v (gate 25v) main power rail ok
                                          RTC section ok.
                                          3vldo ok
                                          5vldo ok.
                                          ECON missing.no 3v and 5v always voltage.
                                          REGN,ACDET perfect.but ACIN missing.No short in ACIN path(good impedence)
                                          Replaced the bq24725a charger ic.but no result.still ACIN not generating.
                                          is this sort of error occurs from...
                                          02-25-2023, 05:06 AM
