Asus Gtx 1060 vram issue
  • Aliasgar Jamali
    • Jun 2022
    • 9
    • India
    guys I have a Asus gtx 1060 which has a Vram issue, I bought the right VRAM and waited a couple of weeks to arrive, but now when I reball the chip it is still showing an error in exact same channel.
    I have reball the proper C0 Channel, and reballing process also went perfectly ( no short in Mvdd and having 65 ohms resistance in the rail )
    Guys, i have a question if the GPU is not artifacting ( no display at all ) and while testing we found out a particular VRAM chip is faulty,
    Can we recover that card?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Re: Asus Gtx 1060 vram issue
    is amount of errors the same as with original chip?
    • nununyang
      • Nov 2022
      • KOREA
      I have a card with the same symptoms.
      did you solve it?
      If you have solved it, please advise.
      • bgrar123
        • Jun 2022
        • 15
        • Poland
        If the chip is not faulty , then re ball once more , i had 1060 from msi gaming x with thick pcb , same problem .
        I had to solder twice , the second time when wicking pcb i left solder on pads and then soldered the same re bald memory , and the problem went away .
        • benwaterson
          • Aug 2008
          • 202
          Maybe look in my thread for advice (very similar issue) https://www.badcaps.net/forum/showthread.php?t=107310
