GA-945GCM-S2L - low voltage on VTT_GMCH
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I have a GA-945GCM-S2L mainboard that I am fixing. All voltage rails are fine in this mainboard, except for VTT_GMCH.
    When CPU is out of the board, VTT_GMCH is fine at 1.22v. In this case, we have:
    Pin1 of Q287: 1.22v
    Pin2 of Q287: 1.5v
    Pin3 of Q287: 1v
    Pin4 of U85: 12v
    Pin5 of U85: 1.22v
    Pin6 of U85: 1.22v
    Pin7 of U85: 1v
    VTT_PWRGD: 1v
    CPU_VCORE: 1.06v
    resistance on VTT_GMCH: 200 Ohms.
    When CPU is inserted, VTT_GMCH is low at 0.2v. In this case, we have:
    Pin1 of Q287: 0.4v
    Pin2 of Q287: 1.5v
    Pin3 of Q287: 0.2v
    Pin4 of U85: 12v
    Pin5 of U85: 1.22v
    Pin6 of U85: 0.2v
    Pin7 of U85: 3.6v
    VTT_PWRGD: 0v
    CPU_VCORE: 0.0v
    resistance on VTT_GMCH: 9 Ohms.
    I have tested it with 3 CPUs (two Celeron-D CPUs and one Pentium 4 CPU) and the mainboard has this same problem.
    I have replaced Q287 and EC169 but the problem persists.
    I did not replace U85 because I think it is working correctly.
    What do you think is the problem?
    master hoarder
    • May 2008
    • 12175
    Re: GA-945GCM-S2L - low voltage on VTT_GMCH
    Pin1 of Q287: 0.4v
    Pin2 of Q287: 1.5v
    Pin3 of Q287: 0.2v
    Pin4 of U85: 12v
    Pin5 of U85: 1.22v
    Pin6 of U85: 0.2v
    Pin7 of U85: 3.6v
    VTT_PWRGD: 0v
    CPU_VCORE: 0.0v
    From what I can tell from this, there is only a 100-Ohm resistor (R1712) between the Gate of Q287 and the output of U85b. Therefore, start by checking R1712. It should be 100 Ohms. If not, that's probably the problem.
    Also, I noticed the following that I think may be an error in the report here:
    Pin1 of Q287: 1.22v
    Pin2 of Q287: 1.5v
    Pin3 of Q287: 1v
    Pin4 of U85: 12v
    Pin5 of U85: 1.22v
    Pin6 of U85: 1.22v
    Pin7 of U85: 1v
    VTT_PWRGD: 1v
    CPU_VCORE: 1.06v
    Since pin 1 of Q287 is tied to the pin 7 (output) of U85b (via 100-Ohm resistor), then voltage on these two should be the same. I don't see how you can have a higher voltage on the MOSFET's Gate than what U85b provides. Likewise, if you measured only 1V on pin 3 of Q287, that would imply VTT_GMCH = 1V. So I can only -assume- you meant to say here that pin 1 of Q287 is 1V, and pin 3 of Q287 1.22V... yes?
    Otherwise, I don't see why else VTT_GMCH would go low when there is a CPU... unless VTT_GMCH is used for deriving some other voltage rail on the motherboard that is shorted, but not turned On until valid CPU is inserted.
    Since this is a socket 775 board, you could also try an unsupported Core 2 Duo CPU, then see if VTT_GMCH goes low or not. If VTT_GMCH is still present with the unsupported VTT_GMCH, then indeed it might be a case of the VTT_GMCH powering some other rail downstream that is shorted and only trying to activate when there is a valid CPU inserted.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      I am sorry. I had a typing mistake. I correct it as below:
      Pin1 of Q287: 1v
      Pin2 of Q287: 1.5v
      Pin3 of Q287: 1v
      Pin4 of U85: 12v
      Pin5 of U85: 1.22v
      Pin6 of U85: 1.22v
      Pin7 of U85: 1v
      VTT_PWRGD: 1v
      CPU_VCORE: 1.06v
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Since the schematics of this mainboard includes an advertising link inside, I cannot attach it here. But it can be found by Google searching.
        Currently, I have no more CPU to test on this mainboard.
        I have checked all the rails connected to VTT_GMCH in the schematics. all of them has higher resistance than VTT_GMCH.
        VTT_GMCH is connected to both PCH and CPU. The CPU connection of VTT_GMCH is 9 Ohms to GND whereas the PCH connection of VTT_GMCH is 200 Ohms to GND.
        Maybe, this 9 Ohm resistance causes the problem. I do not know. I inserted this CPU in another mainboard, then VTT_GMCH become high on that mainboard.
        All the 3 CPUs have about 9v to GND on VTT_GMCH.
        R1712 is 100 Ohms.
        I tested Q287. it does not seem to be shorted.
        The current to VTT_GMCH is provided by VCC1_5.
        U85 provides voltage on pin1 of Q287 to make it On.
        When CPU is not inserted, U85 can make Q287 on easily by putting 1v on pin1 of Q287.
        When CPU is inserted and VTT_GMCH is low, U85 feels this low voltage on its pin6. Then, U85 puts more voltage on its pin7 (about 3.6v) to make Q287 on. but this voltage drops at pin1 of Q287. I do not know why.
        This voltage drop may be due to the low resistance on VTT_GMCH. But I am not sure. Maybe, the low resistance on VTT_GMCH results in a too high current from Pin2 to Pin3 of Q287 that causes Q287 to turn off.
        So I am confused now. Any help is appreciated to discover the defective component.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Once, when CPU is out of the board, I connected VTT_GMCH to GND using a 50 Ohm resistor. then, I observed VTT_GMCH was still stable at 1.22v.
          That means, if the resistance of VTT_GMCH be 50 Ohms, then it will work in this mainboard.
            • 31218
            maybe the fet is failing and cant supply the current.
            if you can turn it on without the cpu, try loading it down with a resistor and see if the output changes.
            it shouldnt because it has a feedback loop to the opamp
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              When CPU is out of the board, I connected VTT_GMCH to GND using a 15 Ohm resistor and a 6 Ohm resistor. then, I observed VTT_GMCH was still stable at 1.22v with each one of these resistors.
              • zaurus81
                HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                by zaurus81
                Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                WITHOUT BATTERY WITH BATTERY
                PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                05-06-2025, 09:48 AM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
              • luzvel64
                I need help HP AIO dan97cmb6d0 with no backligth
                by luzvel64
                Hello everyone, I have this HP AIO computer that does not have a backlight.
                I was making some measurements on the 14-pin connector
                PIN1=ISEN1 0V
                PIN2=ISEN2 0.915V
                PIN3=VLED 17.09
                PIN4=VLED 17.09
                PIN5=ISEN3 0
                PIN6=ISEN4 0
                PIN7=GND
                PIN8=ID0 0
                PIN9=ID1 3.2
                PIN10=ID2 0
                PIN11=ID3 3.2
                PIN12=SIZE0 3.2
                PIN13=SIZE1 3.1
                PIN14=GND
                If someone could guide me on what else I can measure or verify, I would appreciate it.
                I couldn't find a schematic or boardview of this card, if someone had...
                11-23-2023, 11:40 AM
              • mferna14
                Hp 15-cc523ca MB DAG71MB16D0 missing 3.3/5V
                by mferna14
                Hi all., I am working on this Hp 15-cc523ca MB DAG71MB16D0 Rev D. It had the SY8288CRAC BURNT, I replaced it & then no shorts on the 19v rail but still did not turn on. I updated the BIOS Bin & re-soldered the BIOS IC, but still no luck. AD ID is just 0.68 volts & like to share the voltages on PU10 (SY8286BRAC) & PU11 (SY8288CRAC). LED not glowing white/orange on the DC-in jack. Any help would be appreciated. Thanks
                PU10 SY8286BRAC
                PIN1 - 2.8V
                PIN2 - 19V
                PIN3 - 19V
                PIN4 - 19V
                PIN5 - 19V
                PIN6 - 0V
                PIN7 - 0V
                PIN8 - 0V...
                02-14-2022, 04:36 PM
              • DrFalken
                Lenovo ideapad 330-15AST dead
                by DrFalken
                Lenovo ideapad 330-15AST M/B DG425/DG525/DG725 NM-B321 completely dead: no LED, no fan, nothing.
                Flashed BIOS, still dead.
                Some readings:
                +3VL 3.3V
                V20B+ 20.1V
                +5VLP 5.07V
                +5VALW 5.07V
                +3VALW 3.35V
                +1.8VALW 1.79V
                +0.95VALW 0.98V
                +0.775VALW 0.77V
                PU201 (BQ24780SRUYR):
                - pin1 = 19.8V
                - pin2 = 19.8V
                - pin3 = 19.8V
                - pin4 = 25.5V
                - pin5 = 3.30V
                - pin6 = 2.85V
                - pin7 = 0
                - pin8 = 0
                - pin9 = 0
                - pin10 = 0
                - pin11 = 3.33V
                - pin12 = 3.33V...
                04-04-2023, 07:33 AM
