Hp 15-cc523ca MB DAG71MB16D0 missing 3.3/5V
  • mferna14
    • Jun 2018
    • 1024
    Hi all., I am working on this Hp 15-cc523ca MB DAG71MB16D0 Rev D. It had the SY8288CRAC BURNT, I replaced it & then no shorts on the 19v rail but still did not turn on. I updated the BIOS Bin & re-soldered the BIOS IC, but still no luck. AD ID is just 0.68 volts & like to share the voltages on PU10 (SY8286BRAC) & PU11 (SY8288CRAC). LED not glowing white/orange on the DC-in jack. Any help would be appreciated. Thanks
    PU10 SY8286BRAC
    PIN1 - 2.8V
    PIN2 - 19V
    PIN3 - 19V
    PIN4 - 19V
    PIN5 - 19V
    PIN6 - 0V
    PIN7 - 0V
    PIN8 - 0V
    PIN9 - 0V
    PIN10 - 0V
    PIN11 - 4.5V
    PIN12 - 0.015V
    PIN13- 0V
    PIN14 - 0V
    PIN15 - .32V
    PIN16 - 0V
    PIN17 - 3.3V
    PIN18 - 0V
    PIN19 - 0V
    PIN20 - 0V
    PU11 SY8288CRAC
    PIN1 - 3.8V
    PIN2 - 19V
    PIN3 - 19V
    PIN4 - 19V
    PIN5 - 19V
    PIN6 - .6V
    PIN7 - 0V
    PIN8 - 0V
    PIN9 - 0V
    PIN10 -0V
    PIN11 - 4.5V
    PIN12 - 0.015V
    PIN13- 1.5V
    PIN14 - .60V
    PIN15 - 0.06V
    PIN16 - 0V
    PIN17 - 3.3VV
    PIN18 - 0V
    PIN19 - .609V
    PIN20 - .609V
    AD ID is .68V
  • mon2
    • 14238
    Re: Hp 15-cc523ca MB DAG71MB16D0 missing 3.3/5V
    What are the specs of the DC power adapter being used for these tests ?
    What is the voltage of the AD_ID pin without connecting the logic board ?
    • mferna14
      • Jun 2018
      • 1024
      Thanks mon2... The power adaptor is the same I use for every hp 19V 3.42amp ... The power AD_ID on the DC-in Jack connectors is 19.34V
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        AD_ID is correct. Dont mess up un-necessarily here.
        PU10,Pin17 is +3V LDO. This is needed for EC to be powered and light at dc jack. So check for pin17. Most likely +3V LDO is missing. Next check resistance on +3V LDO?? If low very likely kbc shorted. So proceed in this direction and update.
        • mferna14
          • Jun 2018
          • 1024
          Thanks mcplslg123 . I did inform you that the voltage on PU10 pin # 17 is 3.3v. Now only thing is left to check the resistance level, maybe the KBC is shorted too. I even get 3.3v on the ON/OFF button for powering on. & some say that PIN 11 should 19v, is this true as I am only getting 4.5v?? I will surely check all your guidelines & inform you once I get a solution.
          • mferna14
            • Jun 2018
            • 1024
            I checked the resistance level between ground & LDO points near & on the KBC, it's around 142Kohms, so it not shorted & the voltage is 3.3 volts on all these points. But still this connector LED not turning on. I even re-programmed the BIOS, on the 5v coil, I am getting around .609V. I checked the whole motheboard, no components are shorted. What could it be????
            • mon2
              • 14238
              For the 5v coil - which regulator is driving this leg of the circuit ?
              Respectively, this regulator will offer an ENABLE pin. Confirm the voltage of this pin so that we know that the upstream logic for this ENABLE is requesting to turn on this rail.
              If this is an always ON rail then this regulator is not working properly and could be defective or improperly soldered.
              Post the voltage readings of all pins of this regulator and the part number.
              Do you have a schematic for this logic board ? Please link it if on this forum. If not, the details of the regulator should be enough to study by example from other schematics.
              • mferna14
                • Jun 2018
                • 1024
                There are two Enable pins in PU10.. pin 11 has 4.5v & pin 12 is 0v... On top all voltages of PU10 & PU11 are listed.. I have attached the schematics. Please view. I even have the Boardview if required.. Thanks for the help
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Sorry, i overlooked the presence of +3V LDO on PU10. Voltage on Pin11 is absolutely correct, dont go by what people suggest. calculate it yourself. There is a voltage divider involved (PR3264/3268). So 19v(vin)X 150(R2) divided by 499(R1) + 150(R2) will give you exactly 4.4V. So dont get confused when you have schematics. So PU10 seems functional.
                  PU11 is not working properly as you should get +5V LDO on pin15. So replace PU11 and update.
                  • mferna14
                    • Jun 2018
                    • 1024
                    Thanks mcplslg123., I will try this. Just to inform you does this matter, I used SY8288RAC (AWS56A) instead of the original SY8288CRAC (BAC7XM), Does this make a difference & because of this change I am not getting the correct voltages. (I am assuming that they both are the same with same pin configrations & both above chips are the 5v regulators), pls. inform me if this is the mistake I made???
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I've never interchaged them and not sure whether you can do so. Better to replace with exact parts.
                      • mon2
                        • 14238
                        This is most likely due to the a different version of the part being soldered @ PU11.
                        The suffix is very important and fairly sure that the 'C' suffix denotes that the +5V LDO is always ON.
                        Source the exact part number device from Aliexpress or a donor board and test again.
                        SY8288CRAC
                        • mferna14
                          • Jun 2018
                          • 1024
                          Thanks, I will do that & inform you once I get the part replaced. Your help is greatly appreciated.
                          • ein_individuum
                            Missing Capacitator Intel I9-12900KF CPU
                            by ein_individuum
                            I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                            I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                            Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                            08-06-2025, 01:36 AM
                          • ugamazing
                            820-02020 PPBUS_AON missing
                            by ugamazing
                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                            02-05-2025, 04:21 PM
                          • jpreza
                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                            by jpreza
                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                            Looking at the card, it appears to be missing the following:
                            1x 1.0uH inductor - orange square
                            2x...
                            11-01-2024, 10:54 PM
                          • gurj1979
                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                            by gurj1979
                            Hey guys.
                            Need help with this one.
                            Fan not spinning due to missing PWN Fan signal.
                            Also 5 seconds from powering up it freezes, unless in BIOS.
                            But as soon as Windows starts to load, it will freeze.
                            CPU is COLD / Room temp when it freezes.
                            I've replaced the CPU, same problem.
                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                            Replaced fan - same problem.
                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                            08-19-2024, 05:22 PM
                          • salopian
                            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                            by salopian
                            Hello. I would need some advice please.
                            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                            I have already replaced the logic board with another...
                            02-27-2021, 07:30 AM
