Lenovo ideapad 330-15AST dead
  • DrFalken
    • May 2008
    • 122
    Lenovo ideapad 330-15AST M/B DG425/DG525/DG725 NM-B321 completely dead: no LED, no fan, nothing.
    Flashed BIOS, still dead.
    Some readings:
    +3VL 3.3V
    V20B+ 20.1V
    +5VLP 5.07V
    +5VALW 5.07V
    +3VALW 3.35V
    +1.8VALW 1.79V
    +0.95VALW 0.98V
    +0.775VALW 0.77V
    PU201 (BQ24780SRUYR):
    - pin1 = 19.8V
    - pin2 = 19.8V
    - pin3 = 19.8V
    - pin4 = 25.5V
    - pin5 = 3.30V
    - pin6 = 2.85V
    - pin7 = 0
    - pin8 = 0
    - pin9 = 0
    - pin10 = 0
    - pin11 = 3.33V
    - pin12 = 3.33V
    - pin13 = -
    - pin14 = -
    - pin15 = 3.30V
    - pin16 = 0.77V
    - pin17 = 0.82V
    - pin18 = 0.85V
    - pin19 = 0.82V
    - pin20 = 0.82V
    - pin21 = 0.77V
    - pin22 = GND
    - pin23 = 0
    - pin24 = 5.98V
    - pin25 = 5.62V
    - pin26 = 0.82V
    - pin27 = 0.82V
    - pin28 = 19.8V
    What else should I check ?
  • rediii
    h???, spurrrn
    • Mar 2018
    • 490
    • somewhere in europe
    Re: Lenovo ideapad 330-15AST dead
    check ec_rsmrst#, pm_slp_s3 and pm_slp_s4, pltrst#, syson, susp, susp#. do you have 3.3 v on power button (on/off)?
    • DrFalken
      • May 2008
      • 122
      EC_RSMRST# = 1.68V
      PM_SLP_S3# = 0
      PM_SLP_S4# = not present on this board
      PM_SLP_S5# = 0
      PLT_RST# = 0
      SYSON = 0
      SUSP = 5V
      SUSP# = 0
      ON/OFFBTN# = 3.25V
      • rediii
        h???, spurrrn
        • Mar 2018
        • 490
        Originally posted by DrFalken
        EC_RSMRST# = 1.68V
        PM_SLP_S3# = 0
        PM_SLP_S5# = 0
        PLT_RST# = 0
        SYSON = 0
        SUSP = 5V
        SUSP# = 0
        ON/OFFBTN# = 3.25V
        i meant pm_slp_s5, sry. ec_rsmrst# is supsicious
        check all SMB lines
        EC_SMB_CK
        EC_SMB_DA
        remove power and check in ohms mode:
        ec_rsmrst#/RSMRST#_R
        EC_RTCRST#_ON
        susp#
        VCCRTC
        • DrFalken
          • May 2008
          • 122
          i meant pm_slp_s5, sry. Ec_rsmrst# is supsicious
          check all smb lines
          ec_smb_ck
          ec_smb_da
          Ec_rsmrst#/rsmrst#_r
          ec_rtcrst#_on
          susp#
          vccrtc
          ec_smb_ck1 = 3.33v
          ec_smb_ck2 = 3.33v
          ec_smb_ck3 = 0
          ec_smb_da1 = 3.33v
          ec_smb_da2 = 3.33v
          ec_smb_da3 = 0
          EC_RSMRST# = 19.6KOhm
          RSMRST#_R = 19.6KOhm
          EC_RTCRST#_ON = 9.9MOhm
          SUSP# = 100KOhm
          VCCRTC = 1.37MOhm
          • rediii
            h???, spurrrn
            • Mar 2018
            • 490
            ah, i guess i'm wrong ec_rmst# should be 1.8 v (close enough), but since pm_slp_s3 and s5 are missing this could be bad news.
            any chance to flash the ec before further testing...?
            • DrFalken
              • May 2008
              • 122
              Can I flash EC with a simple ch341a ?
              • rediii
                h???, spurrrn
                • Mar 2018
                • 490
                unfortenately not. are you sure you flashed known good bios, though?
                give LID_SW# and PBTN_OUT# a check please (voltage and resistance)
                • DrFalken
                  • May 2008
                  • 122
                  I've download BIOS from Lenovo, expanded and with an hex editor removed the header and reduced to fit.
                  Tomorrow Will report other readings.
                  Maybe a damaged APU?
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 490
                    see you tomorrow then. maybe, but there are other problems possible.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      The bios chip here is 1.8V, Did you used a 1.8V adapter to flash it?
                      If yes, then SUSP# =0V is the cause of concern. This indicates a very likely bad SOC. Try heating on the back side of SOC a bit(not long and just for test purpose) and perhaps susp# will rise. Most of the times SUSP#=0V is 'coz of dry balls under SOC and/or bad SOC.
                      • DrFalken
                        • May 2008
                        • 122
                        LID_SW# = 518KOhm / 3.33V
                        PBTN_OUT# = 24.1KOhm / 3.33V
                        Correctly flashed with a 1.8V adapter.
                        BTW a few minute ago I've noticed a little switch on the m/b and...the laptop boot !
                        Pressing power button on keyboard still doesn't turn on/off.
                        I'm also trying other keyboard buttons, some doesn't work so I'm suspecting a bad keyboard (maybe the customer is omitting a liquid spill ?)
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 490
                          oh, well. that's a shame . but nice.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Keyboards with power button-this is the first thing i check as they often fails. Lenovo has NUVO button on the board, so its easier to test. Btw, I've replaced more then 100 keyboard on lenovo ideapd 320/330 series in last 24 months. they all have power button issue.
                            • DrFalken
                              • May 2008
                              • 122
                              I've contacted the customer and said that the kids spilled some water on the keyboard a few weeks ago.
                              Checked all the keys: almost 50% doesn't work.
                              BTW do You replace only the keyboard or all the upper case ?
                              The original part from EET is pretty expensive (96.25€+25€ shipping+VAT...almost 150€ only for the part) while other suppliers sells only the keyboard for a lower price...
                              • rediii
                                h???, spurrrn
                                • Mar 2018
                                • 490
                                you can replace the keyboard only. there are different methods out there. the "difficult" part is to have the keyboard sitting flush and tight. replacing takes some time, but in most cases, it is worth it. otherwise you could look for a used replacement part.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  I replace only keyboard. carefully applying a little presurre on the meatal cover from one side to lift it up.Dont put too much pressure,else the iron plate on top of keyboard will bend and it'll be difficult to align it properly. Once the cover plate is removed,follow same procedure to remove keyboard. Then time for a new keyboard. Align the new keyboard and just melt the rubber grips with soldering iron across the kbd so that it holds tightly.Then the cover plate-this too has to be fitted with melting/spreading the plastic holes. Entire process takes almost 15-30 mins depending on your practice.
                                  However, if you are not comfortable with the idea of replacing it yourself, just take it to any laptop dealers/service centre-they can fix it may be at a little higher price. These replacement keyboards are all chinese stuff with horrible quality and usually fails every 6 months or so.
                                  • DrFalken
                                    • May 2008
                                    • 122
                                    Thanks everyone for the help and suggestions
                                      Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 05:20 AM
                                      Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 05:00 AM
                                      Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
