I need help HP AIO dan97cmb6d0 with no backligth
  • luzvel64
    • Apr 2017
    • 101
    • Guatemala
    Hello everyone, I have this HP AIO computer that does not have a backlight.
    I was making some measurements on the 14-pin connector
    PIN1=ISEN1 0V
    PIN2=ISEN2 0.915V
    PIN3=VLED 17.09
    PIN4=VLED 17.09
    PIN5=ISEN3 0
    PIN6=ISEN4 0
    PIN7=GND
    PIN8=ID0 0
    PIN9=ID1 3.2
    PIN10=ID2 0
    PIN11=ID3 3.2
    PIN12=SIZE0 3.2
    PIN13=SIZE1 3.1
    PIN14=GND
    If someone could guide me on what else I can measure or verify, I would appreciate it.
    I couldn't find a schematic or boardview of this card, if someone had the boardview I would appreciate it if they could share it.
    I thank you for your help.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Is there a backlit card on the screen itself?
    • luzvel64
      luzvel64 commented
      Editing a comment
      no, only the led connector
  • CapLeaker
    Motorola 22F43 14pin dip identify me
    by CapLeaker
    Got an old Motorola page out controller here. Something honking old. Came in as no workie. Without schematic or anything. So I did some probing around and found two 14 pin DIP IC's that I need an replacement for.
    Motorola 22F43
    Motorola 22F44
    Got no idea what these are.I got semi lucky and found a 22F44 on a donor. Unfortunately the 22F43 is already missing. If anybody knows what these are and find a cross would be greatly appreciated!
    01-21-2024, 09:12 AM
  • luzvel64
    HP 14am-dw1013dx no backligth
    by luzvel64
    best regards, I need help with this laptop with a LAIKA-6050A3202801-MB-A02 (A2) motherboard
    the problem it presents is that it doesn't illuminate the screen, I have voltage on the card and also on the screen but it doesn't illuminate and I can't find the schematic.
    Anyone who can guide me to find the problem, I would greatly appreciate it...
    03-11-2022, 10:31 AM
  • Quantum IC
    LEDs for TV Backligth
    by Quantum IC
    Hello everyone
    I'm new to LED strip LED replacement.
    The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
    I understand that this is due to the tone of the light they emit.
    My Doubt is:
    Can I use the LED with two internal chips without problem?
    Will there be much difference in the picture?
    I'm going to replace all the LEDs.
    Both LEDs (original and replacement) are 3V and the same size....
    03-04-2022, 04:03 PM
  • hmendez86
    Sharp LC-70LE745U no backligth no image
    by hmendez86
    I got this led sharp 70' inch.....i turn on the tv and i did get the geen ligth pulse on the main board and itblinks and 12v on t-con....on the power supply side am getting 83.4v for leds output....i was thinking that regulator on the power supply but neither too is working fine getting 13.2v
    04-26-2020, 08:47 PM
  • wreksta
    55lm670t backligth and sound no picture
    by wreksta
    hi been a while got this set in wondered if anyone can help
    the tv displays no picture other than left side blank right side with a bar that fades
    tries disconnection both ribbon cables to panel and tv displays blank full screen
    right side connected only displays lines that fade
    left side connected only displays half white and lines that fade on right side
    whats the intial diagnosis ?? hoping main board not panel
    main board is eax64307906
    this set has no tcon board
    08-21-2019, 01:52 PM
