Microstar 486 motherboard repair
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    Hi everyone, I wonder if you could help me with repairing a old 486 pc that this year started giving 3 beeps at startup. 3 beeps i understand is a ram error. I checked everything and was about to scrap it when I remember at one time its cmos battery leaked over the pcb. I was wondering if maybe there was still some acid under the ram slots so I took them off and I found a tiny bit and so far found one bad contact between a pcb track and a smd component. I also found smd components had fallen off. Trouble is they are missing but wonder could you tell me what they are. There are others on the board that are identical if you can identify them in the 1st pic if you look between where the ran slots were you will see BC4. What is it? In the other picture you will see some bits with labels starting TC1 TC2 etc what are these too?
  • SluggerB
    • Aug 2020
    • 747
    • US
    Re: Microstar 486 motherboard repair
    Looking at https://en.wikipedia.org/wiki/Reference_designator I don't see "BC" listed. I would assume being in between RAM slots is a capacitor ("C"). Measure it and try replacing the missing spots with those.
    TC is listed as "thermocouple", I would assume it's part of the temperature sensors on the board to prevent overheating
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Usually, no such thing as temperature sensors for anything pre-Pentium II or Pentium Pro!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        • 31047
        nicad strike!
        the caps are probably .1uf but you really need to pull the floppy socket etc and check that area!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          TC8 is a capacitor?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            How the hell did you get the memory slots out of that board in one piece?!
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
              • 31047
              electric desoldering pump can do that - i'v salvaged pci slots that way
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                Thanks for all that info guys, getting the memory slots off is not easy but you definitely need a tiny desolder pump like my tiny Abec one and watch out as those sockets are made up of lots of tiny square plates with a single pin on and they can fall out and almost impossible to see on the bench of floor and a magnet dont pick em up off the floor. Ive lost a few.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  Hi STJ its computer motherboard repairs this time.
                  Ive not been able to get a capacitor readings from my meter and had to use my multimeter x1k diode scale to get a reading from any of the smd components. For example BC4 gives 352k one way and with probes reversed i get 432k. One of the other parts i thought was a resistor also gave different readings both was ie: TC1 also gave 432k & 353k. This makes me think these are either diodes or maybe electro caps. C21 also gives dual readings of 755k & 866k. These are just examples and all the smd components are either grey or brown coloured with no markings or green coloured with a value marked on them which I gather are resistors.
                  So how do i find the value of say BC4 which is the same as the one between the momory slots that had fsllen off and gone missing. Ive ordered myself a dedicated capacitor and ESR meter to see if that can get a better reading. Here is a pic of BC4.
                    • 31047
                    BC are caps - probably .1uf given the age.
                    TC may be inductors
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      I think both BC and TC are capacitors.
                      The "B" and "T" pre-fix in front of the "C" is probably just for specifying its use in the circuit diagram for whoever designed this. I've seen a similar scheme on LCD monitor boards and video cards, where sometimes caps would be referenced with "CE" or just "C"... and sometimes, there would be a pre-fix to the "C" like this case. I don't know if I have any pictures that show it, but I'll dig around in my collection, if I can even remember which monitor board had these kind of weird designator naming.
                      In any case, just replace these with ceramic caps. 0.1 uF might work, but 1 uF should work too for the power filtering ones.
                      I know, right!
                      I've pulled PCI slots out (that AMD Kadoka motherboard in a Gateway Select PC I found a while back, if you remember), but memory slots... never. Perhaps because this is an old motherboard, it doesn't have such thick ground and power planes as newer motherboards. Now I'd like to see someone remove a memory slot on a current gen mobo without damage. Probably still possible, but likely will be much much harder.
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        I know, right!
                        TC may be inductors
                        Thanks everyone for this useful info which is greatly appreciated , cheers.
                        I was wondering, I thoght I saw 2 little bits fall of and its obvious BC1 was one but if there were 2 bits what was the other? All the other pads dont look like they have been used except TC5 which is strange as it has no pads for anything to solder to. Its possible it might have completely fallen off in one lump I suppose. So what do you think should i replace it? Checking with meter it seems the stud (if thats what its called) next to where the pad was has contact to the memery slot hole closest to it and just below to the right. Is this a part I should also replace or is it not nessesary or can be left out without any effect? See photo.
                          • 31047
                          unless your overclocking, you probably dont need all the .1uf caps.
                          they only add stability anyway.
                          what does the board actually do?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            I hate the dreaded beep beep beep ... reminds me of this old 286 board I had. Was really intermittent, sometimes it'd work, frequently not. Was a RAM issue but since it was intermittent, it probably was a broken trace somewhere... finding where is the question.
                            The board ended up finding the round file.
                              • 31047
                              on those old boards, you need to make sure the plating on the ram matches the sockets.
                              gold on gold, or tin on tin.
                              if you mix them you get a galvanic reaction and you have to clean the black coating off your simms every month or 3.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                LOL the same here with a socket 775 motherboard, I upgraded the RAM and then was met with "bleeeep-bleep-bleep". Meant it was reseat-the-RAM-time.
                                Arc A770 16 GB
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  Thats a new one on me stj. I did give all the contacts a clean with alchohol and it did remove a lot of tarnish but still had the beep beep beep. I took the ram out and tried it in another desktop and it was working fine so not faulty ram which is why I removed ram slots especially as I spotted the green battery marks on things.
                                  I converted it to a 3x AAA battery pack instead of the pcb battery so wont happen again if I can fix the 3 beeps.
                                  Its a good motherboard a d has ISA and PCI slots and takes the x586 cyrix processor.
                                  If any of these capacitors are missing does affect the ram modules by letting in noise etc. Would these caps falling of cause the 3 beeps?
                                    • 31047
                                    the problem with AAA is if you use anything other than eneloops they will probably leak when you arent looking!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      But that's the problem here... these old boards don't have so many numerous small ceramics like modern boards do, and they don't have a whole lot of electrolytic caps for capacitance either. So even with just a few missing caps, you might already be hitting stability problems. Better to have more capacitance and filtering than needed than have less.
                                      Again, I'd just go with something more standard, like 1-4.7 uF 16-25V ceramic caps and call it a day. If you have any spare broken GPUs or laptop motherboards you can use for parts, just grab some of the ceramic caps from there.
                                      Also, even if you happen to replace an SMD inductor with an SMD ceramic cap, the worst that could happen is th board will not POST or work. But on the other hand, if you replace an SMD ceramic cap with SMD inductor by mistake, you'll likely create a short-circuit from a power rail to ground, and that can burn traces. So when it doubt, just use a ceramic cap for everything... that is, if you don't feel like doing it the more proper way and checking where each trace goes to determine what the part should be.
                                      Which makes me wonder... what if we plate both contacts with leaded solder? Can that be used to solve plating mismatch? (Granted in this case, it would be a ridiculous idea, given how hard it can be to get solder inside on the contacts of the memory slots, lol.)
                                      +1
                                      Unless he keeps them with long wires away from the board. Then they can leak (and they will) all they want.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        Thats what I do. I either put AAA's in a battery holder/pack usualy stuck to the back of the computer or sometimes put a coin battery holder. I have to do this for some really old computers that use a Dallas RTC/CMOS chip that.has cmos battery combined with the RTC chip. There is a tutotial online that shows just the right places to grind into to get to the chips internal battery connections and then just stick a coin battery in a holder on top of the chip. Google it.
                                        Done a few of these.
                                        • vallllliiii
                                          Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                                          by vallllliiii
                                          Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                                          08-18-2024, 09:21 AM
                                        • tech_guru
                                          Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                          by tech_guru
                                          Hello.
                                          I am having a disappointing motherboard repair with this laptop and I need your help.
                                          This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                          -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                          -PQ102 MDV1525URH
                                          -U17 AOZ1331
                                          -UE1 C8051F383-GQ
                                          -PU800 SY8032ABC
                                          -UI2 SY6288D20AAC
                                          -PU508 RT6220AHGQUF 7P=
                                          -PU100 TPS51225CRUKR
                                          -PU300 TPS51212DSCR
                                          Now, I get all the standby voltages, it turns...
                                          02-16-2024, 09:40 AM
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
