p4mdut
  • rio_bugarin
    • Jul 2005
    • 5
    p4mdut
    hi. Im new here and I am new with M/B repair.
    I had been browsing over badcaps.net for a while when i read about the symptoms of bad caps. I was repairing a p4mdut motherboard but the problem became worst
    The problem was the computer was rebooting constantly. when i inspected the board, i noticed a lot of bad caps. i told the owner that if i tried to fix it, it will either be the problem be solved or become worst so i tried to fix it.
    When i removed the capacitor(1000uF.6.3v) i couldnt find an exact replacement so I tried using 1000uF/10v. Now Im faced with pc not booting up. I notice that it is so slow to detect the hdd and it does not boot.
    I am open to suggestions on repair. This is my very 1st attempt to fix a broken mb and i really need a lot of newbie tips
  • Lance Thornton
    • Jan 2005
    • 84
    Re: p4mdut
    Welcome to the forums! You can always replace a capacitor with one of the same farad rating but higher voltage, if it will fit physically. From the post, you have more than one capacitor that has failed or will fail. You need to replace all of them, it's the only sure way. Make certain you get the polarity right when replacing caps though.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: p4mdut
      That symptom may just be a symptom of wrong HDD jumpering. I had that problem with a Gateway Pentium III PC a while ago when preparing to reinstall all software, because of the fact that the HDDs were Western Digital and at least some Western Digital HDDs require a jumper change, just because you add a HDD to the IDE channel and vice-versa.
      That means when I add a slave HDD, I'm required to change the jumper position on the HDD that's the master, not just setting the jumper on the HDD I added for making it a slave!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • rio_bugarin
        • Jul 2005
        • 5
        Re: p4mdut
        Thx for the reply guys. I wasnt disappointed joining this forum.
        There is more than one badcap on the board. I replaced only one and tried it. I will try to replace all the badcaps and post the result.
        I had knowledge on basic electronics and computer repair so I am aware of their polarity.
        I had the feeling this forum is as lively as pcguide.com. More power to us
        • rio_bugarin
          • Jul 2005
          • 5
          Re: p4mdut
          Im back guys. And im in still in trouble. I cant seem to find 1500uF/6.3v. Can I just replace it with 2200uF/16v?
          I had 1000uF/10v to replace 1000uF/6.3v. I need opinions on using replacements of 1500uf/6.3v. I search all elec shops in our town but cant seem to find them.
          • rio_bugarin
            • Jul 2005
            • 5
            Re: p4mdut
            btw. I dont seem to see the brand of the caps. It just contain G S C on it
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: p4mdut
              you need high quality low esr caps.
              the 2200@16 is not only not likely to be low esr but it is probably too big.
              i cant remember where it is on the forums here but there is a list of reputable suppliers of caps.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: p4mdut
                you can get panasonic FC from :
                http://www.www.rsphilippines.com/
                if you search the forum there was another guy from your country who got his caps there and the service was reported to be ok.
                • rio_bugarin
                  • Jul 2005
                  • 5
                  Re: p4mdut
                  i had performed the operation and i cant believe it was successful. I doubted first because i was only using UNgrounded soldering iron and i placed some caps in wrong position(clumsy me). when i noticed it was wrong, it removed it again ang placed it right. Now it was working fine
                  I would like to thank you guys for helping me out. I really appreciate it.
