I just recapped my board with Rubycon MCZs - when I flick the power switch, the 4 LED lights in the bracket at the back go RED (Manual says CPU problem - but the CPUs worked beforehand). Fans on CPU spin for a second then spen down. I've tried using just one CPU. Any clues? Thanks
MSI 694D Pro2 - Does Not POST After Recap
Re: MSI 694D Pro2 - Does Not POST After Recap
Thanks for the advice, Randy... What are VRMs?
i've never used a multimeter on computers before - only in Physics labs. Do I just power on my machine and bridge the voltmeter across two nodes so they are in series? What should the voltages read?P C N X . com - Computing News At Your Fingertips
FAQ - Testing VRMs
make sure you attached the cpu heatsink properly.days are so short when you actually do something..
check this
https://www.badcaps.net/forum/showthread.php?t=620
Thanks for your replies. Do these VRMs just break by themselves? I've taken great care in removing and replacing components to not knock other parts of the board.
Is there anything I can test without buying a multimeter? I'm a newbie when it comes to electronics. And with the 20 or so pins the VRM has, which two do I put a voltmeter in parallel to?Last edited by opaque; 07-07-2005, 01:28 AM.P C N X . com - Computing News At Your Fingertips
Edit: I just thought what I did different. I tried out my new Coldheat soldering iron (I knew it wasnt a good idea ) - would the sparks be what caused the VRM to fry?P C N X . com - Computing News At Your Fingertips
Originally posted by opaqueEdit: I just thought what I did different. I tried out my new Coldheat soldering iron (I knew it wasnt a good idea ) - would the sparks be what caused the VRM to fry?
coldheat iron=crap.
the money youi wasted on it would buy you a dmm.
return it if you can.
> did the board work before the recap?
Yep
> coldheat iron=crap. the money youi wasted on it would buy you a dmm. return it if you can.
Doubt I could; Hong Kong works differently than North America - the shop comes before the customer =\ So even though I pay much less for Rubycon capacitors (see other thread) I suffer crap customer service and no aftersales service. I should've just waited till I flew back to Canada before buying the cold heat.
> where did the sparks come from?
according to the cold heat site, "It's normal for it to spark"
So what could have failed? Would it be the VRM?
(P.S. I am away on Holiday for the next 9 days so apologies if I don't reply before then)P C N X . com - Computing News At Your Fingertips
Yep, that's where i bought them.P C N X . com - Computing News At Your Fingertips
