694d dead after recap?here is the cure
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this board was sent to me by topcat as dead after recap.
    so i dug in to it and here is what i found
    the vrm controller chip a mosfet and a 10 ohm resistor as seen in pic
    btw the sc1182csw is pin compatible with the 1164 these boards came with.
    this board works fine now.
    i guess it wont mind a leaded resistor since i dont have any smt that size.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    *takes notes*. only dead-after-recap I've had to fix was a board I recieved DOA, and a quick inspection showed a few SMT caps were broken off. bent the leads sideways on some radial tantalums and soldered them in their place. haven't had to dig into VRM circuitry yet.
    --Randy
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I've repaired a lot of SMT's broken off, mainly on VP6's by the CPU sockets when someone carelessly removed a heatsink. That one obviously got by me
      Glad ya got some use out of it, I was gonna pitch it in the trash after I stripped it down. Glad I didn't.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • AK0R
        • Mar 2005
        • 204
        Is it just the lighting in the picture, or is that MOSFET really that bad? It certainly looks like it's had a little extra heat-treating. The solder connection for the MOSFET case to the board doesn't look all that good, either.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          its just the light.
          that is an after repair pic.
          btw the dead giveaway was that vrm being at 0.0 v
          • jinu_j
            Dell 2209WA - power supply - Fusible Resistor replacement
            by jinu_j
            Hi
            I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
            1. FR950 - blown fusible resistor - 0.2 Ohm 1W
            2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
            3. R835 - Blown Resistor - 20KOhm SMD resistor
            4. D930 - Shorted Schottkey Diode...
            05-03-2025, 10:51 PM
          • youpla
            PowerColor rx 5700xt dual fan : current sense resistor
            by youpla
            Hi everyone,
            I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
            The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
            The card wasn’t displaying anything after this fix.
            When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
            I tried to resolder it with a hot air station, but the resistor wouldn’t...
            12-01-2025, 07:52 AM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
