Software to analyze Video RAM faults on graphics cards?
This is a sticky topic.
Re: Software to analyze Video RAM faults on graphics cards?
Could someone explain me installation in english?Comment
For some reason I can not download 3rd part.It stucks at around 4Gb.Comment
Can anyone share on some upload website 3rd part...for some reason I can't download more then 4 gigs of that part?Comment
Is it possible to create installation on USB pen drive rather then external HDD?
I have 64 GB pen drive.Comment
Thanks for the tips on how to install new vram test and also windows repair.
works nice but the new amd test like rx6800 do you use rx5700?
i only have rx 5000 series and radeon 7 there.
is this correct?
[QUOTE=Fasse-sweden;1160774]Hi, I have the same problem...downloaded the linked version but that one is i english...is that correct?[/QUOTE
I dont think the language matters if its the correct version of diskgeniusComment
how to vram test amd rx6800xt or 6900xt models? i have 5 partition bootable test disk but cannot test at 6800-6900 selection? thanksComment
Thank you for the links!
I have two questions regarding MATS for which I couldn't find concrete answer to them elsewhere. Hopefully it's not OT here:
1. Is it possible to have a faulty chip (that for example always crashes the card upon driver install) even though MATS doesn't report any errors?
2. Can a faulty memory stop MATS from running altogether (empty report.txt)?
Thank you so much.Comment
I ran this test in a failing 3070. It gave me 64 errors on both banks of channels A and C.
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 64 0
FBIOA1 0 64 0
FBIOB0 0 0 0
FBIOB1 0 0 0
FBIOC0 0 64 0
FBIOC1 0 64 0
FBIOD0 0 0 0
FBIOD1 0 0 0
Any ideas where to look for the problem? Could it be that all four banks went bad the same "mild" way? or should I be looking into something else such as power delivery, etc?Comment
guys have somebody newer version of lorg of gpu or simmilar utility to check memory errors on 6900XT and 6950XT gpu ?Comment
I've got a problem with rx5700xt. Card is detected, drivers loaded, but when i use furmark to stress it, i've got artifacts.
I've tried ./tserver -boardtest=memfa, but no errors
so i/ve tried to increase clocks by using ./agt -mem=1000, but clocks are still 300MHz for engine and 875MHz for vram
Do you know, how can i ncrease clock to do vram tests at more stress condition?Comment
If anyone is having problems with the 32GB 3.rar file then you can try download it from my google drive.
I split it the third file into 4 parts of around 8Gb each. Just download all parts to the same folder then right click on 3.part1.rar and use WinRAR to unpack it and it will reconstruct the whole file
Of course you need WinRAR installed to do this but it is free to download.
1.rar
https://drive.google.com/file/d/1eDV...ew?usp=sharing
2.rar
https://drive.google.com/file/d/1uEt...ew?usp=sharing
3.part1.rar
https://drive.google.com/file/d/1Ten...ew?usp=sharing
3.part2.rar
https://drive.google.com/file/d/1qTT...ew?usp=sharing
3.part3.rar
https://drive.google.com/file/d/1zy6...ew?usp=sharing
3.part4.rar
https://drive.google.com/file/d/1uOP...ew?usp=sharing
Hello Dicky96 , did u ever solved your problem ? Im running into exactly the same problem u have/had . Kind regardsComment
Or did anyone else find a solution for this ?
"[firmware bug] TSC_DEADLINE disabled due to Errata: please update microcode to version 0x22 (or later)
acpiphp_ibm: ibm_acpi_init: acpi_walk_namespace failed
Booting TinyLinux 20.10
Error: initrd version 20.10 does not match TinyLinux version 18.07"
Thanks in advance !Comment
yes for RTX4090 there is only where do you always get the latest version?
https://www.youtube.com/watch?v=q_kWonOzoagComment
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by sam_sam_samThis is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it... -
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... -
by japlyticOn this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...12-30-2022, 11:12 PM -
by myth77I am having a big problem in how to recognize gpu fault or vram fault on laptops or desktops when picture is partially broken or with artifacts or....Sure, i measure resistance and trying to conclude what is a bad part but it is very time consuming so i emaganed this thread for the people to share pictures of repaired video cards... what was the bad picture before? and when they repaired it, was it a vram fault or gpu chip fault...I think that it would help other members a lot (sure would help to me).
I have found only a few threads on the internet (but very old) that are describing what... - Loading...
