Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
  • japlytic
    • Oct 2005
    • 2086
    • Valve/tube stuff, cartoons
    On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
    So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics could not be performed because the system halted on failure.
    It works with a CPU supporting video and a display connected to a motherboard port; I've found a default BIOS setting set to always use the onboard video which the original CPU (most likely functional) does not have and therefore, unable to start even with a known working video card in an expansion slot with a connected and working display/cable.
    Updating the BIOS to version F21 fixed this problem along with the issue that a GC-ALPINE RIDGE Thunderbolt card was not being detected under Windows 11 even though it was in a x4 PCIe slot and showing up in the BIOS screens.
  • leonada2008
    ASUS TUF3 video memory power supply failure
    by leonada2008
    ASUS TUF3 3 fan version, under high load, image loss, black screen, flash back, large area of video memory reports unknow error, suspected to be video memory power supply failure, now request a boardview, thank you
    04-23-2025, 01:59 AM
  • KernalMooley
    MSI MPG Edge Z690 wifi DDR4 will not turn on
    by KernalMooley
    Hi, I have a MSI MPG Edge Z690 wifi DDR4 that was working fine and no will not turn on. I have tried 3 known working psu, tried manually shorting the power pins on JFP1 connector since this issue started. Up to this point I would sometimes have to press the power button 2-3 times before it powered on. I have inspected the board with a microscope and cannot see any physical damage to any pcb/smd components. If I flash the bios with usb stick using the flash back button on I/O panel the whole system fires up whilst flashing the bios over and all board leds light up etc. It just doesnt respond to...
    03-05-2026, 02:30 PM
  • DynaxSC
    MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
    by DynaxSC
    Hi Folks
    I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
    Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
    09-29-2024, 04:27 PM
  • karlp028
    MSI PRO Z690-A WIFI DDR4 doesn't start
    by karlp028
    I bought a used MSI PRO Z690-A WIFI DDR4 and it does not start up at all so I started looking into what was going on. PWRBTIN makes it to the SIO, but then I noticed that PWRBTN# (e.g. PSOUT#) was shorted even before I tried to start it. At first I thought the short was in the SIO, but after some more tracing that was the only SIO pin that was shorted and I found more shorts on 3VDSW, SYS_3VSB, PCH_0P82_VSB and a couple of other PCH pins. The chipset gets pretty hot even in standby, so I'm 99% sure the short is in the chipset. I've seen a few other posts around the same problem with this board....
    02-04-2025, 10:21 PM
  • karlp028
    MSI PRO Z690-A WIFI DDR4 no reaction to the power button
    by karlp028
    I've got an MSI PRO Z690-A WIFI DDR4 that has no reaction to the power button. I have been doing some exploration to try to determine what is wrong with it.
    The front panel PSIN# pin has 3.3V on it, so i started tracing from there to the SIO, which is a Nuvoton NCT6687D. Connectivity from the front panel PSIN# to pin 61 on the SIO is good and when I short PSIN# to GND then pin 61 goes low as it should.
    However, I noticed that SIO pin 61 PSOUT# was already low, even before I activated PSIN#. Does this mean the SIO chip is hosed or could there be another explanation? I'm...
    11-29-2024, 07:04 PM
