Asus A8N-E BIOS settings lost when unplugged
  • bigbeark
    • Jan 2010
    • 661
    I finally got this one to boot after removing and replacing the RAM several times.The first boot was really slow. I finally saw the monitor LED stop blinking and after an endless wait it finally booted into the BIOS. After checking the BIOS battery again (fine) it now boots up quickly, but loses the BIOS settings after it's unplugged.
    I have another one of these that has the same BIOS loss when unplugged.
    Any fix for this?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Asus A8N-E BIOS settings lost when unplugged
    could be a bad cmos battery holder. i had a couple of asus boards with that issue. i tried reflowing the two solder pads for the cmos battery holder but no dice. replacing the cmos battery holder with a new one or known working one from a scrap board fixed it. the cmos/bios settings loss that is.
    as for the slow sluggishness, that can sometimes happen if the cpu inserted is not supported and u need to update the bios to support the cpu. that is all i know.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      That's what happens with my Asus socket 1366 motherboards, when a Radeon RX 580 is installed. Confirmed that issue to be caused by the Radeon RX 580. (At least the P6T series!)
      It was a strange video card compatibility issue when that happened to me.
      It's possible that very late Nvidia video cards cause the issue, as well and thus the GeForce GTX 970 or GeForce GTX 980 is possibly the latest you can install without the "CMOS-loss-issue".
      For AMD/Radeon, that could be up to R9 290X or before that, maybe as far back as the Radeon HD 7xxx series or before that.
      I never saw the CMOS-loss issue with the Asus Strix GeForce GTX 970 installed.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • bigbeark
        • Jan 2010
        • 661
        Chaos, thanks for the tip. Replaced the battery holder using one from a dead Acer board, and it worked!
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • intelg
          HP Elitedesk 800 G6 lost BIOS admin password
          by intelg
          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
          Here is the hardware identification specs:
          HP EliteDesk 800 G6 Desktop Mini PC
          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
          BIOS ver S21 Ver. 02.05.01 01/05/2021
          Born on date: 07/26/2021
          SN MXL11841GN
          SKU 3X8V9UCHABA
          UUID 8116E79EF6FFE94DB0B98A3188270C5C
          SYSTEM BOARD ID 8710
          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
          11-03-2023, 02:05 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • YG007
          Asus BIOS How To Reset To Default Settings?
          by YG007
          Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
          I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
          06-05-2023, 08:22 PM
