Gf5600fx
  • icemachine
    • Jun 2005
    • 5
    Gf5600fx
    Hallo
    I'm read this forum quite often and i learn more ebaut computer equipment. So i try to fix something. For begin I'm buy and successful fixed GF5200FX next GF2MX400 and ... I'm try FX5600 but it isn't so easy. for begin i'm re-caped this card... it help but ........ when I run 3Dmark2001se i seen a few vertical and/or horizontal line. and is's change. ftp echivment ist quite good. Next when i continue test card will crashed and i must restart my computer.
    For time i have raplaced cap it is posible to play for a game for example NF2U or Airfix dogfighter but view isn't clear. I can obserwe same kind visible of shape and image blurring(some times). I think it is case of Voltige Regulator - APM company .... but i'm not sure.....
    if you konow something useful i will be grateful for your answer for this post.
    IceMachine
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Gf5600fx
    post a pic of your card.
    sounds like you have a few more caps to replace.
    • icemachine
      • Jun 2005
      • 5
      Re: Gf5600fx
      Unfortunetly i have replaced all capacitors. I used "hitano" i think it is quit good, because when i used it before i have good result. However graphic 2D and 3D graphics when i replaced capacitors is going better , but i have stil artefacts in 3D. I suspect APM2014 (N - mos enchanced power driver) but i haven't ony one to replaced.
      Recently I,m looking in Net for ony sheme(description) of voltage in GF card but i can't finde ony one. I wiill be very gratefuly when anybody help my find some one.
      This only good result serch:
      https://www.badcaps.net/forum/login.php?do=logout&u=394
      but it isn't enought.
      Thanks a lot
      ps.
      sorry but i don't know haw can i add picture, because when i click on the icon dialog box ask me of same kind of text, so i don't know what i have done with it.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Gf5600fx
        to add a picture you click on "manage attachments" then upload the file from your hard disk.
        • icemachine
          • Jun 2005
          • 5
          Re: Gf5600fx
          So i try to add picture my card GF5600Fx, this is real picture but cappacitors is replaced.
          • icemachine
            • Jun 2005
            • 5
            Re: Gf5600fx
            So finaly I add picture <happy>
            • icemachine
              • Jun 2005
              • 5
              Re: Gf5600fx
              Hallo Somebody have service manual to GF 5600 ???
              it will be very useful for me
              Thanks a lot for help
              ps. I looking for service mnual to others Nvidia card also
              • Dev Goose
                Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                by Dev Goose
                Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                What Happened
                The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                12-13-2024, 03:13 AM
              • a316
                a2442 820-02098 usb-c begin charge only after reboot, until first disconnect
                by a316
                briefly, one usb-c port, when connect when OS running, or in recovery mode, stays on 5v and 000 amp. If I reboot ( or connect usb-c on shutdown state), it makes 20v andbegins charging, until first disconnect/connect.
                *** on shutdown state, it makes 20v, charging stops after 4-6 seconds in rare case,, sometimes never stops. If not disconnect, it stay on 20v and charges even after OS boot. after disconnect/connect (ON state) it always stays 5v 000 amp
                it is not software issue, it happens only 1 port. other ports including magsafe3 is ok
                MB was after liquid...
                02-04-2025, 10:37 AM
              • Longon
                Behringer Pro Mixer DJX-750
                by Longon
                Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                08-11-2025, 02:17 PM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • spleenharvester
                Synology MR2200ac mesh router, UART connection - login details?
                by spleenharvester
                This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
                I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
                Code:
                sudo minicom --baudrate 115200 --device /dev/ttyS0
                09-02-2024, 01:19 PM
