a2442 820-02098 usb-c begin charge only after reboot, until first disconnect
  • a316
    • Oct 2024
    • 24
    • Georgia
    briefly, one usb-c port, when connect when OS running, or in recovery mode, stays on 5v and 000 amp. If I reboot ( or connect usb-c on shutdown state), it makes 20v andbegins charging, until first disconnect/connect.
    *** on shutdown state, it makes 20v, charging stops after 4-6 seconds in rare case,, sometimes never stops. If not disconnect, it stay on 20v and charges even after OS boot. after disconnect/connect (ON state) it always stays 5v 000 amp
    it is not software issue, it happens only 1 port. other ports including magsafe3 is ok
    MB was after liquid damage, where to look?
    *** luquid damage was on cpu side, so CD chips are other sida and was undamaged
    like smc reset helps. but where can be problem?
    thank you for reply, pro-s
  • a316
    • Oct 2024
    • 24
    • Georgia
    FIXED!!! CF812 was loose (no contact due liquid damage, resoldered and all come back)
    it was marketd as CRITICAL in schematics
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • rilley
      MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
      by rilley
      I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
      I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
      My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
      And the resistor L4004 is literally burned.
      From what I see from the schematics, it does not affect any other rails, only the connection to the display...
      07-10-2024, 01:57 AM
    • drscoot
      usbc connector replacement on mobile
      by drscoot
      I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
      The battery is still charging (red led), but no power on.
      I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
      07-13-2025, 02:37 PM
    • macabook
      A2442 TOUCHID NOT WORKING
      by macabook
      I have an issue with a Mac A2442 , that had initially a short circuit on Q5800 after replacement it turn on without any other issue, only finger print not working. I follower the post " MacBook Pro M1 2021 A2442 Touch ID stopped working" by measuring in diode mode all SPI seems ok, but when checking for voltage i notice something strange regarding PP1V2_S2.
      The chips UT620, UT520, UT540 are powered by PP1V2_S2 (according schematic and board view), this voltage is missing, and when I check continuity with PP1V2_S2 rail, found that it is not connected to it. Compared on another...
      04-13-2025, 10:28 AM
    • TechSplendid
      MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
      by TechSplendid
      Hi All,
      I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
      Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
      04-09-2025, 02:13 AM
