IPIBL-LB loses BIOS settings after power off
  • Sparkey55
    • Jan 2010
    • 1523
    Re: IPIBL-LB loses BIOS settings after power off
    Do you use the same HDD for Windows 7 and XP?
    When you install the OS are you connected to the internet via a firewall?
    Have you zero filled (wiped clean) the HDD before installing OS?
    Have you scanned your installation and update media for rootkits?
    Trying to narrow down if hardware or software problem
    Your PSU has not been ruled out nor has the CPU as yet.
      • 21293
      Have you checked the crystal .
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Originally posted by Sparkey55
        Check to see if you have the switches connected in the correct pins on the header.
        No switches connected - just motherboard on a wooden surface, touching jumper momentarily to necessary places
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          No
          No, completely isolated
          Yes, using manufacturers' diagnostics
          No, but I am using Win7 SP1 with update, downloaded from Digital River when it was available, and SHA1 checked before burning to DVD
          And same DVD has been used many times, without issue
          Have tried multiple PSUs and CPUs
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            No - how do you check crystal?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              Originally posted by pfrcom
              FWIW, other weird behaviour is, if I short Reset pins on Front Panel header, more often than not there's a delay, then it powers off
              At that point just shorting the Pwr pins won't start it - I have to switch power off & on before it will start again
              So I need to remember to use Ctrl-Alt-Del for reset
              Something fundamental seems to have gone wrong with its electronics - reckon I'm
              That is quite strange, indeed.
              My IPIBL-LB is in a HP PC, so it doesn't have a reset switch. But wonder if will do the same thing. If not, then for sure something may not be quite right with yours.
              With that said, perhaps consider giving the motherboard a wash with detergent and warm water, then dry for a few days. Maybe something conductive has gotten under one of the chipsets and is shorting something? I know that using case screws with non-smooth heads will sometimes produce solder and/or metal shavings where the screw head grinds against the motherboard or case. If these shavings got underneath a BGA chip, I think that could cause intermittent trouble. So when in doubt, I wash things and make sure to force plenty of water under whatever BGA chip I think may have gotten affected. Never really had a case where resolved anything, but for the tiny off-chance that it might be possible, I still do it.
              • Sparkey55
                • Jan 2010
                • 1523
                Another thing to try if you have a seperate chip programmer, reflash the bios chip, that will clear it out for sure. Or buy another chip with the bios preprogramed.
                I had a Epox motherboard that would stop posting with a C1 error and could not flash on board so took it out and reflashed in programmer now works fine.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  KUDOS to Sparkey55
                  I desoldered its MX25L8005 BIOS chip and reflashed it with my Rube Goldberg setup - https://www.badcaps.net/forum/showpo...55&postcount=9
                  Involving:
                  1. Erase
                  2. Blank check
                  3. Program
                  4. Verify
                  5. Dump
                  6. Compare dump to original
                  So it should have been well & truly cleared out
                  Didn't feel that confident after all the setbacks along the way, but after the acid test of booting an existing Win7, then shutting it down and turning the power off, it didn't produce the dreaded message after starting again
                  Even left it powered off overnight to confirm no message in the morning, before posting this
                  Has certainly reinforced my opinion about Macronix chips being cheap & nasty, compared to Winbond or SST
                  Thanks to everyone who contributed
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #29
                    Yay! Good to hear a success story here!
                    I wonder if that got rid of the random BSODs you experienced too.
                    I raise this question, particularly because I pulled my HP PC with the same motherboard, and first several boots, it was doing some weird things, including throwing a BSOD once or twice. But after a day of use, all trouble went away. I then turned off and disconnected the PC for a few days to see if the issue is perhaps cap related (it does have a Bestec 250-12Z PSU that hasn't been recapped... though all caps appear OK visually... which we know doesn't mean much, but still.) So far, though... it's been OK.
                    Anyways, I'll keep this thread in mind if I see any more odd behavior with my board. In any case, really glad that you were able to fix your and that you updated the thread.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      The P.O.S. board failed again
                      Subtly different symptoms this time
                      Before, it showed message on HP BIOS display in graphics mode, even though it was set to Diagnostic messages = Enabled
                      This time it shows a text message shortly after the message about F10 for BIOS setup
                      Undecided whether to replace the crappy Macronix SPI chip this time, or just do irreparable damage to the board so I'm not tempted to waste more time on it
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        For what it's worth I've had the experience that a once corrupt BIOS chip can be due to hardware problem.
                        I.e. replacing the chip curves the illness of the thing becoming corrupt intermittently again ad-infinitum.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          Oh noes.
                          I guess leave it to ASUS to build an unreliable board - at least from that era. (On that note, I can't think of any DDR2 -era boards that were as reliable as the old DDR boards, if bad capacitor issues are put aside for a moment.)
                          Yeah, I know this feeling. Have quite a bit of hardware in that boat. In the end, I don't destroy any of it though, just in case I need to pull parts to save something else. Have done that quite often with finicky/artifacting video cards. As for my finicky motherboards - good for testing gutless PSUs "as is" - that is, see if they can power up and not blow up (especially when they might have bad caps.)
                            • 21293
                            Heres a IPIBL-LB Boardview .
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #34
                              Thank you! Sharing schematics/boardviews is always appreciated.
                              I don't need it ATM, but I will save it just in case.
                              Sometimes, I find that certain motherboards from the same manufacturer can often have similarities, which may allow you to troubleshoot one motherboard if you've worked on a similar one. So I imagine this boardview might also be similar to other s775 ASUS boards from the era.
                              • AquaMan Ua
                                by AquaMan Ua
                                05-17-2025, 09:40 AM
                              • throwaway327
                                by throwaway327
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                06-18-2025, 05:52 PM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • YG007
                                Asus BIOS How To Reset To Default Settings?
                                by YG007
                                Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                                I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                                06-05-2023, 08:22 PM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
