Asus p8z77 v lx
  • rodtoo401
    • 8
    Asus p8z77 v lx
    I picked up this motherboard. When I try to boot it .The motherboard stop at the ASUS boot screen and that`s it . No keyboard, light comes on for it that`s all .Does anyone have an idea where to start looking for the problem? I have a bios chip programmer .That has been done and tried from the first to the last bios and new bios chip. Where to look for the problem ?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Asus p8z77 v lx
    For socket 775:
    Clear the CMOS. And if you're using all 4 slots (if 4 slots on motherboard)
    go into BIOS and raise the DRAM voltage to 1.90 V, if it's DDR2, with 2 of the RAM sticks removed. Then insert the remaining RAM afterwards...
    For socket 1155:
    Clear the CMOS.
    If using 4 sticks, take 2 of them out and depending on the RAM, manually setting the DRAM voltage to 1.65 V, before inserting the remaining 2 DDR3 SDRAM sticks, may solve the problem...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • rodtoo401
      • 8
      Re: Asus p8z77 v lx
      I can not get into the Bios at all, the keyboard stops working .The lights on it come on and that is all> I have tried a p/2 keyboard and usb no luck with either. As it starts to boot I can get the caps lock key to work and that stops, as soon as boot Asus screen comes up .All the socket pins look good and straight. I have tried changing out ram and, CPU, power supply nothing changes
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: Asus p8z77 v lx
        I dunno. My techniques were for if the BIOS boots, but freezes at the motherboard logo...
        Arc A770 16 GB
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Re: Asus p8z77 v lx
          Clear the Bios settings using the jumper provided on the mainboard. try to find it. There are lots of easy solutions which you can try one by one. If you got no result, you can think of reprogramming the Bios chip. But first, make a backup of the original content of the Bios chip.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Re: Asus p8z77 v lx
            Did you try this trick? My Asus P6T Deluxe has this annoying bug, where for the BIOS to enter the setup utility, when turning it on, when you see the first screen, (or you hear the first bleep) (the video card BIOS text for me) I must quickly slide out the USB plug of the keyboard and slide it back in the USB port, then keep mashing the "del" key! (wtf lol)
            That's at least when using my Corsair Strafe keyboard on my Asus P6T Deluxe.....
            Arc A770 16 GB
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              Re: Asus p8z77 v lx
              that is right. It is possible the problem is caused by USB incompatibility or fault.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Re: Asus p8z77 v lx
                Before attempting a BIOS reprogramming, try the simple stuff first. Namely, that's:
                - strip down system to minimum hardware: CPU, CPU heatsink, *one* stick of RAM only, onboard GPU (may use PCI-E GPU if board still doesn't boot after below tests).
                - re-seat RAM a few times. Try different RAM slots. Use good quality RAM, if possible - i.e. Samsung or Hynix OEM. Kingston and Crucial is okay. Corsair I wouldn't trust.
                - re-seat CPU and also try running board flat with CPU heatsink on the CPU but not clamped to the board (this is to prevent board warping, which can sometimes affect marginal CPU socket BGA).
                - re-check all jumper settings
                - make sure CMOS CR2032 battery has good voltage (at least 2.9V) - some boards may refuse to boot with a drained or no battery... though I suspect that's NOT the problem with your board)
                - make sure you are using a known good PSU. In fact, please tell us what PSU you are using (manufacturer and model).
                - check and possibly replace chipset heatsink thermal compound
                - try the "MemOK" button (I doubt that would do anything, but what the heck!)
                If none of that does anything, you can try reprogramming the BIOS. But do try to backup the old one first, as caspian suggested.
                • rodtoo401
                  • 8
                  Re: Asus p8z77 v lx
                  I have tried 3 PSU on it and battery is good, different ram and CPUs. I do have 2 mosfets that I read continuity between source and gate by the ram slots .They are A09 N03N CDL0358. So Maybe bad ? Keyboard is a PS/2 and have tried usb too.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Re: Asus p8z77 v lx
                    Source and Gate or Source and Drain? The former would be bad, indeed.
                    Probably better if you post pictures of your board and specifically point out which MOSFETs read shorted (and how). That should tell us if there is possibly a problem or not.
                    • piernov
                      • Jan 2016
                      • 4436
                      • France
                      Re: Asus p8z77 v lx
                      Boardview if this is of any use.
                      If there was an issue with the RAM power supply circuit, you won't get an image and BIOS POST would fail when detecting the RAM.
                      But first identify which MOSFET you measured and what did you measure.
                      • rodtoo401
                        • 8
                        Re: Asus p8z77 v lx
                        I downloaded Fritzing and Can`t open the files: parse error [1] at line 1, column 1: error occurred while parsing element. Please help
                        • brethin
                          • Dec 2008
                          • 1907
                          Re: Asus p8z77 v lx
                          Been awhile since I worked at ASUS but if the board has a speaker audio connection attach a speak to it and it will give you voice messages of the issue. If that doesn't work use a post card in the pci slot and get your error there.
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • futadmytro
                            Asus g713qm-es94 stuck on boot bios problem
                            by futadmytro
                            sn^M4NRKD02753616E
                            MB- g533-6050a3250201-MB-A03
                            Stuck on boot after ROG logo, did not enter to bios
                            In flash bios , laprop boot but have video issue
                            orig bios...
                            06-25-2025, 08:07 AM
                          • lrouw84
                            by lrouw84
                            Hi there,
                            01-28-2023, 01:31 PM
                          • alimohebiyan
                            Need Factory BIOS for ASUS TUF506IU
                            by alimohebiyan
                            My laptop was recently repaired, but now it does not have a proper BIOS.
                            I was able to get the corrupted BIOS file (dump) from my technician.
                            I need help to either:
                            • Repair/fix this corrupted BIOS file, or
                            • Get the original/default factory BIOS for my laptop.
                            If anyone has the correct BIOS or can guide me on how to restore it, I would really appreciate your help.
                            Motherboard Model: [DABKXBYBAC0 REV : C]
                            Serial Number: [L8NRCX03847534D]
                            Thank you in advance!
                            Today, 10:24 PM
                          • oragano
                            ASUS ex-b250-V7 motherboard bios corrupted - by me
                            by oragano
                            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                            10-17-2024, 02:53 AM
