I picked up this motherboard. When I try to boot it .The motherboard stop at the ASUS boot screen and that`s it . No keyboard, light comes on for it that`s all .Does anyone have an idea where to start looking for the problem? I have a bios chip programmer .That has been done and tried from the first to the last bios and new bios chip. Where to look for the problem ?
Asus p8z77 v lx
Re: Asus p8z77 v lx
For socket 775:
Clear the CMOS. And if you're using all 4 slots (if 4 slots on motherboard)
go into BIOS and raise the DRAM voltage to 1.90 V, if it's DDR2, with 2 of the RAM sticks removed. Then insert the remaining RAM afterwards...
For socket 1155:
Clear the CMOS.
If using 4 sticks, take 2 of them out and depending on the RAM, manually setting the DRAM voltage to 1.65 V, before inserting the remaining 2 DDR3 SDRAM sticks, may solve the problem...Last edited by RJARRRPCGP; 01-23-2018, 09:36 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
Re: Asus p8z77 v lx
I can not get into the Bios at all, the keyboard stops working .The lights on it come on and that is all> I have tried a p/2 keyboard and usb no luck with either. As it starts to boot I can get the caps lock key to work and that stops, as soon as boot Asus screen comes up .All the socket pins look good and straight. I have tried changing out ram and, CPU, power supply nothing changesComment
Re: Asus p8z77 v lx
I can not get into the Bios at all, the keyboard stops working .The lights on it come on and that is all> I have tried a p/2 keyboard and usb no luck with either. As it starts to boot I can get the caps lock key to work and that stops, as soon as boot Asus screen comes up .All the socket pins look good and straight. I have tried changing out ram and, CPU, power supply nothing changesASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: Asus p8z77 v lx
Clear the Bios settings using the jumper provided on the mainboard. try to find it. There are lots of easy solutions which you can try one by one. If you got no result, you can think of reprogramming the Bios chip. But first, make a backup of the original content of the Bios chip.Comment
Re: Asus p8z77 v lx
That's at least when using my Corsair Strafe keyboard on my Asus P6T Deluxe.....Last edited by RJARRRPCGP; 01-27-2018, 05:23 PM.ASRock B550 PG Velocita
Arc A770 16 GB
Re: Asus p8z77 v lx
Before attempting a BIOS reprogramming, try the simple stuff first. Namely, that's:
- strip down system to minimum hardware: CPU, CPU heatsink, *one* stick of RAM only, onboard GPU (may use PCI-E GPU if board still doesn't boot after below tests).
- re-seat RAM a few times. Try different RAM slots. Use good quality RAM, if possible - i.e. Samsung or Hynix OEM. Kingston and Crucial is okay. Corsair I wouldn't trust.
- re-seat CPU and also try running board flat with CPU heatsink on the CPU but not clamped to the board (this is to prevent board warping, which can sometimes affect marginal CPU socket BGA).
- re-check all jumper settings
- make sure CMOS CR2032 battery has good voltage (at least 2.9V) - some boards may refuse to boot with a drained or no battery... though I suspect that's NOT the problem with your board)
- make sure you are using a known good PSU. In fact, please tell us what PSU you are using (manufacturer and model).
- check and possibly replace chipset heatsink thermal compound
- try the "MemOK" button (I doubt that would do anything, but what the heck!)
If none of that does anything, you can try reprogramming the BIOS. But do try to backup the old one first, as caspian suggested.Comment
Re: Asus p8z77 v lx
I have tried 3 PSU on it and battery is good, different ram and CPUs. I do have 2 mosfets that I read continuity between source and gate by the ram slots .They are A09 N03N CDL0358. So Maybe bad ? Keyboard is a PS/2 and have tried usb too.Comment
Re: Asus p8z77 v lx
Probably better if you post pictures of your board and specifically point out which MOSFETs read shorted (and how). That should tell us if there is possibly a problem or not.Comment
Re: Asus p8z77 v lx
Boardview if this is of any use.
If there was an issue with the RAM power supply circuit, you won't get an image and BIOS POST would fail when detecting the RAM.
But first identify which MOSFET you measured and what did you measure.Attached FilesOpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Re: Asus p8z77 v lx
Been awhile since I worked at ASUS but if the board has a speaker audio connection attach a speak to it and it will give you voice messages of the issue. If that doesn't work use a post card in the pci slot and get your error there.Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by futadmytroAsus g713qm-es94 stuck on boot bios problem
sn^M4NRKD02753616E
MB- g533-6050a3250201-MB-A03
Stuck on boot after ROG logo, did not enter to bios
In flash bios , laprop boot but have video issue
orig bios...-
06-25-2025, 08:07 AM -
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by lrouw84Hi there,
I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
by ferah831208I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
- Loading...
