GA-8IG1000MK with bloated Rubycon MBZ (pic heavy)
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Acquired this recently, and found hard to believe ...
    ... five bloated Rubycon MBZ around PCI and AGP slots
    Perhaps not too surprising when one sees heat discolouration underneath the FETs between AGP & PCI1
    Matched by discolouration beneath VRM
    Latter weird, considering VRM has Rubycon input and Sanyo output
    Was advised board had been liquid cooled, and stopped working reliably if multiple DIMMs were used, after a leak
    So I also removed caps between memory slots, to find
    Bloated MBZ replaced by Sanyo WG - also replaced two non-bloated MBZ
    DIMM area, after clean-up
    Board overall, after cleaning off coolant stains with wet microfibre cloth
    Could be worse though
    Unfortunately multiple DIMMs are still not reliable - board's BIOS swaps between OK & Fail for 2.5V health status
    However two DIMMs were OK for four passes of Memtest86+
    And did a clean XP install without an issue
    Then Prime95 didn't even get through a single pass
    And stress test of Aida64 also didn't go too far
    Aida64's sensor display showed some weird numbers for 2.5V - swapping from ~0.8V to ~1.7V
    However Aida64 also showed 5V as 4.1 - but DMM measured 5.03 on spare Molex connector
    PSU is a recapped Antec SL300S
    Caps between AGP & PCI1 heat up to temperature most unpleasant to put finger on
    Where to go from here ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: GA-8IG1000MK with bloated Rubycon MBZ (pic heavy)
    The attachments don't work. The link in red shows bad 2004-2005? Nichicon HM and KZG. No surprise there. The software sensors are never reliable, best not to place any trust in them (but the low +5V reading could be a pin or two on the ATX 20-pin connector, if it really is low). Is there any discoloration underneath the DIMM area? Any chance of trace corrosion (as the resulting effects of the leak from the liquid coolant) or oxidization that may be causing only one DIMM to work, even after cleaning the board? The two linear regulators by the AGP slot, I would imagine, do run precariously hot. No surprise there either.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      They're hosted on Badcaps, not sure what could be the problem
      Can anyone else confirm it's an issue for them please
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        He's right,I can't see them either.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            I should have known better ...
            ... the penny finally dropped that I was using a 3.0 Northwood with a missing pin
            So I swapped in a 3.0 Northwood with all pins intact, and you've guessed it ...
            ... self-tests 1024K and 8K of Prime95 passed, and continuing
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Clicking on the IMG tags in question brings up a page that says the attachments are invalid. Uploading the attachments without the aforementioned IMG tags should work.
              I phrased too briefly - originally I followed FAQ and clicked mountains? icon for each inline image, then pasted each upload's URL - which yields IMG tags
              FWIW, I cleared Waterfox cache, then I couldn't see images either
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I fixed the images.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Originally posted by Topcat
                  I fixed the images.
                  Thank you, thread now much cleaner
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3266
                    • Singapore
                    well i guess thats the issue with water cooling. due to that, the fallacy is to neglect cooling or ventilating the board properly. so what i think happened was that there was no airflow over the board due to water cooling being used. so the mosfets all overheated and discoloured the pcb. the bloated caps over a large area of the board is a telltale sign of a poorly ventilated pc case.
                    for normal air cooling, the cpu fan will give a slight breeze over the board. i've seen a number of cases in overclocking forums whereby when someone upgraded to water cooling, the overclocking got worse or more unstable. the culprit was found to be lack of airflow over the board and overheating mosfets during overclocking. after some mosfet heatsinks were added and a side panel fan installed blowing air over the board, it was business as usual overclocking.
