ibm lga775 sff board.blown mcz
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    customer brought this in complaining of "fast write"errors and disk corruption.
    hmmm wonder why????
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: ibm lga775 sff board.blown mcz
    A leaking Rubycon? Which series?
    Look at the KZGs (suspect ones?) and caps 3 mm above the pcb: did IBM fear the soldering could damage the board?
    Zandrax
    Have an happy life.
    • gdement
      • Jan 2007
      • 690
      IBM seems to do that a lot. They install caps with a lead spacing that doesn't match the board, so they leave a gap where the leads are bent outward.
      • decried
        • Nov 2008
        what brand of caps are these capacitors near 24pin connector? (pic #2) Small, without went, with letter "R" in frame logo. I have same on my Intel DP35DP mobo near audio output.
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          Not very fond of this policy: leads can bend or short if they're long enough.
          Zandrax
          Have an happy life.
          • bgavin
            • Jan 2007
            • 1355
            Wow, looks like terrible quality control.
            KC8: is that a special anti-static carpet on your bench?
            Just curious, as I figured most carpet like that would be an ESD nightmare.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              it is just plain old carpet.
              in the winter i spray once a week with staticide.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Is it me, or is that board like 10 feet long?
                • welp
                  PS5 Disk Tray issues.
                  by welp
                  I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                  Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                  Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                  So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                  With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                  12-19-2024, 02:04 PM
                • DynaxSC
                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                  by DynaxSC
                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                  The behaviour is also really very strange, i.e.:
                  • The disk shows always up in BIOS - so it is recognized, so far so good
                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                  02-23-2025, 01:33 PM
                • Stanley1843
                  Windows 11 disk no boot
                  by Stanley1843
                  I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                  I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                  DISM /Online /Cleanup-image /Restorehealth
                  The DISM.... command shows me the error 87.
                  sfc /scannow
                  chkdsk
                  bootrec /FixBoot
                  bootrec /ScanOs
                  bootrec /RebuildBcd
                  For some reason it writes(Total identified installations 0) like there no...
                  10-18-2025, 04:41 AM
                • chth96
                  LG GCC-4521B cannot read any disk
                  by chth96
                  I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                  But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                  And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                  But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                  02-13-2024, 07:31 AM
                • madura2010
                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                  by madura2010
                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                  i checked the connectivity of ribbon=good communication with hard and motherboard
                  changed hard disk and checked=3f0 error persist
                  sata power=+5v available
                  Then checked data capacitors=all good
                  Then checked data lines path connectivity to pch=all good
                  reflashed...
                  03-12-2023, 09:09 AM
