Recently my PC wouldn't start. It is an ABIT KV7-V. KT600 north bridge, VIA 8237 south bridge. 20-pin ATX power connector, two IDE channels, two SATAs. I'm running the Athlon 2900 (TigerDirect). After trying several power supplies (PC P&C 350, CoolerMaster 430, PC P&C 500), checking the ATX power button with an ohmmeter, and getting a second KV7-V off of eBay and repeating these tests, I'm still having the same problems:
It will randomly fail to start for 7-10 days at a time. If the lights and fans come on, they'll stay on for 0.1 to 0.2 seconds before going dead. At some point, it will resume booting and working as if nothing was ever wrong. Until the next time. Looks like both boards are acting the same.
Looks like Rubycons were used, no bulging, nothing burned.
The board (and CPU) are the only things common in all of this (assuming no shorts in the case). Even trying to boot with and without the UPS doesn't seem to affect things. Never overclock, set timing, etc. to automatic in BIOS. It *_should_* work.
I ended up getting a new system (64-bit) to "buy my way out of the problem" (XP Pro 64-bit can be thought of as a $139 splash screen, since I already paid for, and had the benefits of, XP Home on the Abit).
I'm at or near the final BIOS release on both boards. Any ideas what could be wrong? Capacitors that did not *_visibly_* fail?
