P5PE-VM question ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: P5PE-VM question ?
    anyone knows ? or have the schematic of this board ?
    I can't find the datasheet for the chip and the schematic of this board....a challange for fixing it ...
    • bianchi77
      • Jun 2016
      • 1121
      my northbridge temperature is reaching to 70 degree celcius on heatsink, is it the main problem ?
      chip = intel SL99Y
        master hoarder
        • May 2008
        • 12168
        • Bulgaria
        #83
        chip = intel SL99Y
        Yes, 70C is way too much.
        How are you measuring this temperature, though?
        Just as a check to make sure you're not measuring the temperature wrong, try to touch the heatsink. Anything above 50C should feel uncomfortably hot, and 60C or more should be enough to cause a reaction for you to pull your hand away.
        • bianchi77
          • Jun 2016
          • 1121
          I measured it with my DMM temperature meter...
          I let it run few more seconds and it was nearly 100....so I pulled out the power supply just in case this chip will burn....I bought the replacement already and see what happen next...
          Anyway what's the cause of faulty northbridge ?
          • bianchi77
            • Jun 2016
            • 1121
            Does anyone have the schematic of this Asus P5PE-VM ? cheers
            • bianchi77
              • Jun 2016
              • 1121
              Originally posted by diif
              Post #25. The same way you tested that crystal.
              I test mine with one of these. http://www.aliexpress.com/item/DIY-K...413364646.html
              I bought that frequency counter but I can't measure 32KHz crystal..it's showing 0 always....I tried with 20MHz and 4MHz crystal it works....what should I change ? thanks
              • bianchi77
                • Jun 2016
                • 1121
                Is it possible that my northbridge faulty ? It's integrated with VGA
                  Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                  Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                  various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                  Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                  trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                  what is wrong with your PC in just seconds. It saves you time and money.
                  Our new and improved design...
                  11-01-2024, 06:29 AM
                • MisterAIL
                  PS5 digital / No Power / No Beep / Good power supply
                  by MisterAIL
                  Brought a non functionnal PS5. Apparently only a bad PSU...
                  No beep, nothing.
                  After some tests i found this :
                  - PSU is fine (12 volts stable)
                  - 12 volts line is shorted
                  - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                  - By the way, nothing change. No signal, no power, no beep.
                  Mesuring all rails with my workbench psu (12 volts input)
                  - 0.00 amp drawing
                  - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                  03-12-2024, 03:24 PM
                • ktmmotocross
                  Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
                  by ktmmotocross
                  Hello.
                  Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
                  i have ps5 repair guide but not ps5 pro so link me to it if u know it
                  04-27-2025, 01:10 AM
                • teokarafou
                  Lenovo Ideapad 5 15ARE05-2 beep
                  by teokarafou
                  Hello team ,I a have ideapad 5 ,that has a weird issue ,it start up and does 2 beep ,and when I want to type password to login,keyboard doesn’t work ,check video
                  Lenovo ideapad 5 15are05
                  s/n: pf2hngt3...
                  12-27-2024, 08:40 AM
                • Ymotaqi
                  ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
                  by Ymotaqi
                  The motherboard does not POST and has the following symptoms:
                  When the power button is pressed, the fans and RGB turns on.
                  When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
                  The motherboard does not beep.
                  None of the diagnostic LEDs light up.
                  USB voltage is off.
                  VCORE voltage is off.
                  The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
                  I would appreciate it if anyone could guide me on the cause of the problem.
                  01-12-2025, 04:15 AM
