CPU CAP replacement
  • Philly Cheese Steak
    • Mar 2011
    • 114
    CPU CAP replacement
    Was wondering the best approach for this cap replacement, the CPU is a heat sink itself isn't it?
    Also I need advice on finding a CAP to match the others, how to I measure(with a multi meter)of course but what settings?
    I got a micro scope and have done a few micro solder things, but assume I know nothing cause pretty much I do!!
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: CPU CAP replacement
    Looks like this Cap is the same rating with the caps around him , so if you can test those 10 surrounding and find the same ratings , then logically he is the same .
    Palladium caps are almost everywhere , you can find a similar , even in an old cdrom or a defected board .
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Hot air station. If you don't have one, a hot plate set to 100C should bring the temperature up enough for you to be able to solder it with your iron. But if it works like that you should just leave it alone. Unless you're planning on overclocking it where it could make a difference.
      A working TV? How boring!
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • groomit
        Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
        by groomit
        I just replaced the battery on a Google Pixel 5.
        After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
        Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
        The rubber seal is on again (as mentioned in various suggestions in other forums).
        This smells like a cold or broken solder joint. So I'd like to reflow...
        06-11-2025, 02:21 AM
      • Glaval
        Sony OLED XBR-65A8G 4 flashes
        by Glaval
        Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
        01-23-2025, 04:04 PM
      • petemanuk
        BGA solder balls not connecting - help pls
        by petemanuk
        So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
        I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
        I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
        11-16-2022, 05:21 AM
      • myth77
        UV solder mask - high temp resistent, recomendation?
        by myth77
        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
        Is there any solder mask...
        03-28-2022, 04:04 AM
