Hello and nice to meet you to the forum! I bought this board with bad caps! the previous owner says that is not working at all! i bought it in order to do a full recap espacially on the vrm cirquit! it has nine OST capacitors 680uf 4v on the vrm and the bulged ones are 6. i was thinking of using the nichicon S8 series 560uf 6.3 volt with 0.008 esr in order to change all the Ost and i want to ask you if it is a good choice or may i buy some panasonic fm or fr which are cheaper but the efr is 0.056! i am asking you your opinion because i am afraid of the survival of this board but on the other side i have read in some posts here that these boards with g31 will survive with a recap! i am sorry for the only one blur picture,when i receive it i will take some much more quality ones! thank you very much!
Msi g31m3-f (ms-7528)
Re: Msi g31m3-f (ms-7528)
Go with the 560uF Nich S8 polies. I use 560uF polies to replace those 680uF OSTs on MSI boards all the time.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Thank you very much for your repply "c hegge"! i will post again with my procedure! is it good to replace and all the kzg's at the same time? what is your opinion about the existing board? can these msi be survived only with a recap? thanks again!Last edited by tioklou; 01-21-2014, 04:29 PM.Comment
If the board has KZGs (or TKs, Teapos, or any other OSTs), then definitely replace them too.
For the four taller ones which are near the rear IO ports, you can use 470uF 16V solid caps. I used Nichicon NE 470uF 16V on an identical board to this before, and it worked perfectly. (although you can leave them alone of they are Panasonic FJ or FL. I can't tell from the pic what they are).I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
The condition of those caps, look more like the VP6-era and socket 478-era.
More like the photos folks were used to seeing during the old school badcaps.net times!Last edited by RJARRRPCGP; 01-25-2014, 06:56 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
That's pretty common on those boards. The OSTs really don't like being placed directly under the CPU heatsink.I love putting bad caps and flat batteries in fire and watching them explode!!
You better replace them, then
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by momakaI've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
This one was actually suggested to me by ChaosLegionnaire.... -
Hi guys,
I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
Looking for someone experienced with older PC boards who uses...07-29-2025, 11:53 PM -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
Channel: General Capacitor Questions & Issues
Got 4 CCFL 16/10 monitors for free.
The resolution is almost Full HD (1680x1050)
VGA Input only is a bummer though.
Uses cheap TN panel with terrible viewing angles.
Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
- Loading...
