Hi I recently bought a 2nd hand Ge-force 2080Ti, it all works ok runs fine and no issues stress testing with furmark . However I get this screen when powering on (see video link) , is this cause for concern ? .
2080Ti startup issue ?
Tags: None
Should check with another motherboard and display before messing with the graphics card.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
I just checked and it seems to be on 30 Hz with no option to change it, I plugged it into the other display port and that does not show the scrambled image on startup and its on 60Hz but if i touch the cable it goes to black screen like the connector is bad .Comment
Not done a VBIOS update before , will take a look / .
Make a backup of your current BIOS before doing anything (can be done with GPU-Z).
Flashing a new BIOS can be done with Nvidia NVFlash or with a USB programmer.
Latest rom for your card is here: https://www.techpowerup.com/vgabios/...i-11264-200203
Besides all the VBIOS stuff, check your display cable as well (just in case it´s that simple...)Comment
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... -
by db80Hello friends,
I've been racking my brain over the past few months on the following issue:
I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
I tried all the common alleged „fixes“... -
Assuming...7 Photos -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... - Loading...
