2080Ti startup issue ?
  • moss99
    • Oct 2013
    • 50
    • United Kingdom
    Hi I recently bought a 2nd hand Ge-force 2080Ti, it all works ok runs fine and no issues stress testing with furmark . However I get this screen when powering on (see video link) , is this cause for concern ? .
  • FZG
    • Sep 2022
    • 111
    I guess this is some scrambled version of the mainboard vendor logo and the loading circle. Can you access BIOS and if so, does it display correctly?
    • moss99
      • Oct 2013
      • 50
      • United Kingdom
      Just gone into the bios and all looks like it should, interestingly it seem it only does it from power up not on a restart 🤔
      • FZG
        • Sep 2022
        • 111
        In the video it looks like it also happens when starting the PC from sleep mode.
        What exact model of GPU are we talking about?
        You shoud try to update the GPU VBIOS, if there is an update available. Use GPU-Z to check your current firmware version.
        • piernov
          • Jan 2016
          • 4437
          • France
          Should check with another motherboard and display before messing with the graphics card.
          • FZG
            • Sep 2022
            • 111
            Can´t see how the display would be at fault here though
            • moss99
              • Oct 2013
              • 50
              • United Kingdom
              The video is from startup, it does not do it from sleep, Gpu msi gaming trio geforce rtx 2080 Ti
              • moss99
                • Oct 2013
                • 50
                • United Kingdom
                The motherboard is a fairly new asus PRIME Z690-A (LGA1700) and both were working fine before I put this card in.
                • moss99
                  • Oct 2013
                  • 50
                  • United Kingdom
                  I just checked and it seems to be on 30 Hz with no option to change it, I plugged it into the other display port and that does not show the scrambled image on startup and its on 60Hz but if i touch the cable it goes to black screen like the connector is bad .
                  • FZG
                    • Sep 2022
                    • 111
                    How does it work with the other connectors? Should have 3xDP, 1xHDMI, 1xUSB-C.
                    Did you check VBIOS version with GPU-Z? Latest version is 90.02.42.00.14. If everything else fails, might be worth to give it a try.
                    • moss99
                      • Oct 2013
                      • 50
                      • United Kingdom
                      Version : 90.02.30.00.65 is what I have
                      Not done a VBIOS update before , will take a look / .
                      • FZG
                        • Sep 2022
                        • 111
                        Make a backup of your current BIOS before doing anything (can be done with GPU-Z).
                        Flashing a new BIOS can be done with Nvidia NVFlash or with a USB programmer.
                        Latest rom for your card is here: https://www.techpowerup.com/vgabios/...i-11264-200203
                        Besides all the VBIOS stuff, check your display cable as well (just in case it´s that simple...)
                        • moss99
                          • Oct 2013
                          • 50
                          • United Kingdom
                          It was just a dirty connector, it looked a bit dull compared to the other 2 ports so I gave the cable plug a squirt of contact cleaner worked it a bit now its working fine..
                          • shahnld
                            Lenovo legion 5 pro startup issue
                            by shahnld
                            Good day Experts
                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                            08-24-2025, 12:31 PM
                          • db80
                            Lenovo Ideapad 5 15ARE05 startup issue
                            by db80
                            Hello friends,
                            I've been racking my brain over the past few months on the following issue:
                            I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                            If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                            Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                            I tried all the common alleged „fixes“...
                            07-06-2024, 05:58 PM
                          • rounin
                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                            by rounin
                            🛠 Original Issue
                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                            04-19-2025, 01:18 AM
                          • ugamazing
                            by ugamazing
                            12-17-2024, 07:05 PM
