My PC doesn't boot -No BIOS on screen
  • sciconf9
    • Apr 2007
    I changed the hard drive a month ago and updated to WinXP.
    It is a pc I built in 2004- P4/2.5 with ECS motherboard (L4....)
    Its been working fine - I shut it down last night and it doesn't boot today.
    The light comes own and I hear the fan. I don't hear a "clicking" sound - Monitor is blank - No BIOS appears on the monitor.
    What is happening?
  • AKBessy
    • Feb 2007
    • 131
    Re: My PC doesn't boot -No BIOS on screen
    sciconf9, you were over at the craiglist forum weren't you? If so, glad to see you came over. These guys are professional and very helpful. Be sure to check out all the boards here - there's a variety.
    For starters, check out the pictures of bad capacitors (there's tons of pictures on this site! LOL) Here's one thread with pictures: https://www.badcaps.net/forum/showthread.php?t=424
    Check out your board and your power supply unit. Post back with questions and pictures of your board, etc... if you have some.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      how are the caps on the mobo looking?
      • starfury1
        • May 2006
        • 1256
        Welcome to the forums
        You say its been working fine for the last month
        Did you try and reset the BIOS to default ?
        (jumper or whatever on the MB)
        I would as suggested above check caps
        The system is about 3 years old and stuffed caps is a good possibility depending on the motherboard/psu
        Has it been flaky at all
        rebooting or freezing over the last year or so, if it has then caps are defiantly on the cards
        Also what type of Power supply have you got in the box.
        If you have a spare PSU that will run the system and you know that it works try that
        Also check plug unplug connectors. data and power on the HDD etc
        Make model of psu model of MB.....maybe even what the HDD brand and model is
        since you say no clicking and I am assuming you meant the HDD clatter as it starts up.
        You now need to work out what part of the system is giving you problems.
        • stevo1210
          • Oct 2006
          • 4156
          I had a Gigabyte motherboard a while back which didn't boot and only the fans spun. It turned out that the Deer rebranded PSU killed the Intel ICH5 southbridge.
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • Max029
            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
            by Max029
            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
            TY,
            08-18-2024, 08:28 PM
          • mitchw
            HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
            by mitchw
            Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
            After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
            After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
            I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
            04-29-2025, 03:45 PM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
