Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
There is another transistor around the one you removed for the chassis intruded error, that makes it do that. That can be jumpered too, but first things first:
1. Clean up the area of the Winbond chip very well with isopropyl alcohol and a toothbrush.
2. Remove battery, clear CMOS, replace with new battery.
This is a sticky topic.
Hi again. Thanks for the help @Th3_uN1Qu3 , I really appreciate your effort.
When I fixed the Chassis Intruded error. Now I am getting another message that is:
"new cpu installed please enter setup to configure your system"
PLEASE HELP!!!!Leave a comment:
hi, my board is P5Q SE2. Using the beep of DMM I found that DMM gave a beep when with the transistor next to the transistor you said to remove.
Please help!11Leave a comment:
Correction - the drains are going to be wired to the pins of the Winbond chip. You should check continuity from the chassis intrusion pin to the gate, which is the first pin on the left, on the side where there are two pins.Leave a comment:
Ok that's a good pic. With the board powered ON, measure voltage at the CHASSIS jumper. Find the pin that has somewhere between 1 volt and 3.3v. Could be anything in that range.
Once you found it, turn all power OFF and unplug the power supply, and set your multimeter to beeper. One probe goes to that pin you found with the voltage on it, and with the other probe measure on the little 3-pin transistors around the Winbond chip. You should find one that beeps on the single pin at the top, which would be the collector or drain.
Return with these results and i will try to help you further.Leave a comment:
https://www.dropbox.com/s/ibhv2svdt6...35.22.jpg?dl=0Last edited by bobbymih; 09-01-2014, 08:41 AM.Leave a comment:
Please post clear pictures of the mainboard and a close-up of the Winbond chip area.Leave a comment:
Th3_uN1Qu3
Please help me with my PK5 DELUXE mother board that surely need that "remove transitor fix" cant know for sure wich one is it and i don't wanna mess something up.
ThanksLeave a comment:
got same problem on my P8h61-m2, help me please! tiaLeave a comment:
Have an easier workaround, following are the steps :
<1> Remove the front USB and audio connectors from MB
<2> Remove the reset switch connector
<3> Reset BIOS using the Jumper / removing CMOS
<4> Reset BIOS Settings and reboot your PC and things should be Up and running.
Let me know if this works for you too.Leave a comment:
try replacing the jumper that bypasses the chassis switchLeave a comment:
I have seen this error on a P6T Deluxe V2 socket 1366 motherboard, is it likely the same solution ?
Also, it appears that cleaning the board well could resolve this as well, is that correct ?
As old as this thread is, its the first solution I've seen, in a LOT of looking, that seems to delineate the exact CAUSE of the fault. Very, very useful information.
Thanks very much to the OP, btw !Leave a comment:
SOT-23 is just the package specification (look up SOT-23 on Google images and you will see what I mean). The actual marking on the transistor will vary, depending on what it is.Last edited by momaka; 04-03-2014, 11:31 PM.Leave a comment:
I know this is an old thread but I have a P5E3 with same problem. My chassis intrusion connector is by the front panel header and the board power LED and the super I/O controller is in the top corner like the P5KE shown but no transistors are near it. Can anyone help me identify the correct sot-23 on my board? I certainly would appreciate it. There are 4 transistors surrounding the intrusion connector but none are marked sot-23.Leave a comment:
can u plz help me my motherboard is P5k-VM
and i also get the same problem (chassis intruded fatal error system halted)
dont know how to fix that :/Leave a comment:
Good job!
Another board saved from the landfill.
Yes, the fans remain spinning. I'll clear the CMOS again and I'll clean the board.Leave a comment:
Shouldn't happen. What happens when you try to turn the computer off? Do the fans remain spinning?
Try to clear CMOS again and also clean that area on the board well using isopropyl alcohol and a toothbrush.Leave a comment:
I found a new spot, but it seems that I can't get my computer to wake up anymore if it goes to sleep, and also it doesn't want to turn off anymore. Could this have something to do with it? Should I just find an alternate point again?Leave a comment:
by playitmy system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
few years back ps2 mouse stopped working, but ps2... -
by harpOh, sadly it has no screw...
What is the proper way to open this so that not destroy rubber?
I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it.... -
by OKRPKCOMPAsus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
Chassis intrude,pls check yours system
Fatal error, system halted
Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
Thanks in advance...-
by vishal24I m Having Lenovo Ideacenter B320 all in one.
when i Press F1 for BIOS, Asking for password. after 3 times wrong password, give error Fatal Error System Halted.
i forgot my bios password.-
by angelosHi all,
I got in this beast of a tv of which i am needing advice on how to access the AUTO GEN function so that i can test if my main board is perhaps faulty.
There is a 4 pin plug on the plasma control board but i don't know what to do there and i cannot find any reference on the web to it.
I have added photos to jar your memories...
This is PDP42V8 chassis.
Any suggestions would be greatly appreciated.
Angelos... - Loading...
