[HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
    too good of caps?
    Originally posted by tmiha71
    Nice thread, but I see lot of Panasonic's FJ caps...
    If there are at the rear USB connectors, I would replace them with Rubycon XYG 8x11 1000uF, even used ones are good for that place...
    Reason for replacement - too good caps (??), on wrong place ...
    To add, through time, inductive, capacitive, or even resistive bond is created, and is main cause of that behavior...
    Most likely some caps died, and can not swallow current... And because they're FJ's - most likely PSU caps took big hit...
      master hoarder
      • May 2008
      • 12175
      Originally posted by kc8adu
      x2
      I don't see how "too good of caps" would cause a problem either. The PSU's wires have enough resistance so that the PSU never really "sees" the low ESR of those "too good caps" on the motherboard.
      • tmiha71
        • Apr 2010
        • 130
        That's for sure, that PSU wires have higher resistance than traces on mobo....
        ROFL
        • fu-raz
          • Jan 2014
          • 5
          • Netherlands
          This helped me fix my Asus P5E deluxe. It also had the Chassis Intruded fatal error. Took me only a few seconds to find the right transistor, thanks to the directions.
          It's not perfect yet. Is it possible that my 3.3v point comes on too late? If I do a cold boot it gives me the error, but when I reset everything is fine.
          Anyway, I wanted to say thanks and give people looking for a solution for their P5E deluxe some directions. So I added a picture of the fix for the P5E deluxe. The transistor is located in the bottom left corner of the motherboard. Underneath the winbond chip.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            I see you pulled 3.3v from a resistor. Maybe that's part of some other circuit and it takes a little while to charge. Try finding a capacitor with 3.3v on it, that should charge up quickly (as it'll be directly across a 3.3v regulator) and it should work on a cold boot as well.
            The capacitors are the brown colored parts with no marking on them.
            A working TV? How boring!
            • fu-raz
              • Jan 2014
              • 5
              • Netherlands
              #26
              Thanks, I'll find another spot and post the picture. If it goes into hibernation or sleep mode now, I can't get the computer to turn back on heheh
              Still, this is a lot better than Chassis Intruded: Fatal Error...
              • fu-raz
                • Jan 2014
                • 5
                • Netherlands
                #27
                I found a new spot, but it seems that I can't get my computer to wake up anymore if it goes to sleep, and also it doesn't want to turn off anymore. Could this have something to do with it? Should I just find an alternate point again?
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  Shouldn't happen. What happens when you try to turn the computer off? Do the fans remain spinning?
                  Try to clear CMOS again and also clean that area on the board well using isopropyl alcohol and a toothbrush.
                  • fu-raz
                    • Jan 2014
                    • 5
                    • Netherlands
                    #29
                    Yes, the fans remain spinning. I'll clear the CMOS again and I'll clean the board.
                    • fu-raz
                      • Jan 2014
                      • 5
                      • Netherlands
                      #30
                      So, there we go... Thanks for the help Th3_uN1Qu3! Found a new 3.3v point, cleaned the board and reset the CMOS. Everything is working now.
                      In the attachment is my final solution for the Asus P5E Deluxe
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #31
                        Good job! Another board saved from the landfill.
                        • wasay345
                          • Jan 2014
                          • pakistan
                          #32
                          can u plz help me my motherboard is P5k-VM
                          and i also get the same problem (chassis intruded fatal error system halted)
                          dont know how to fix that :/
                          • jimmyd
                            • Mar 2014
                            I know this is an old thread but I have a P5E3 with same problem. My chassis intrusion connector is by the front panel header and the board power LED and the super I/O controller is in the top corner like the P5KE shown but no transistors are near it. Can anyone help me identify the correct sot-23 on my board? I certainly would appreciate it. There are 4 transistors surrounding the intrusion connector but none are marked sot-23.
                              master hoarder
                              • May 2008
                              • 12175
                              #34
                              SOT-23 is just the package specification (look up SOT-23 on Google images and you will see what I mean). The actual marking on the transistor will vary, depending on what it is.
                              • gn2
                                • Dec 2013
                                • 5
                                I have seen this error on a P6T Deluxe V2 socket 1366 motherboard, is it likely the same solution ?
                                Also, it appears that cleaning the board well could resolve this as well, is that correct ?
                                As old as this thread is, its the first solution I've seen, in a LOT of looking, that seems to delineate the exact CAUSE of the fault. Very, very useful information.
                                Thanks very much to the OP, btw !
                                  • 31139
                                  try replacing the jumper that bypasses the chassis switch
                                  • Vishwasjoistmk
                                    • Jun 2014
                                    • India
                                    #37
                                    Have an easier workaround, following are the steps :
                                    <1> Remove the front USB and audio connectors from MB
                                    <2> Remove the reset switch connector
                                    <3> Reset BIOS using the Jumper / removing CMOS
                                    <4> Reset BIOS Settings and reboot your PC and things should be Up and running.
                                    Let me know if this works for you too.
                                    • formybhe
                                      • May 2014
                                      • Philippines
                                      #38
                                      got same problem on my P8h61-m2, help me please! tia
                                      • bobbymih
                                        • Aug 2014
                                        #39
                                        Th3_uN1Qu3
                                        Please help me with my PK5 DELUXE mother board that surely need that "remove transitor fix" cant know for sure wich one is it and i don't wanna mess something up.
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          #40
                                          Please post clear pictures of the mainboard and a close-up of the Winbond chip area.
                                          • playit
                                            ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                            by playit
                                            my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                            my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                            few years back ps2 mouse stopped working, but ps2...
                                            12-23-2024, 06:05 AM
                                          • harp
                                            Howto open schuco rubber plug
                                            by harp
                                            Oh, sadly it has no screw...
                                            What is the proper way to open this so that not destroy rubber?
                                            I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it....
                                            12-16-2022, 02:35 PM
                                          • OKRPKCOMP
                                            B85m-e rev 1.02 chassis intrude error
                                            by OKRPKCOMP
                                            Asus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
                                            Chassis intrude,pls check yours system
                                            Fatal error, system halted
                                            Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
                                            Thanks in advance...
                                            07-20-2022, 10:12 AM
                                          • vishal24
                                            Lenovo ideacenter B320
                                            by vishal24
                                            I m Having Lenovo Ideacenter B320 all in one.
                                            when i Press F1 for BIOS, Asking for password. after 3 times wrong password, give error Fatal Error System Halted.
                                            i forgot my bios password.
                                            08-10-2021, 03:18 AM
                                          • angelos
                                            LG 42" Plasma TV - Howto invoke AUtO GEN?
                                            by angelos
                                            I got in this beast of a tv of which i am needing advice on how to access the AUTO GEN function so that i can test if my main board is perhaps faulty.
                                            There is a 4 pin plug on the plasma control board but i don't know what to do there and i cannot find any reference on the web to it.
                                            I have added photos to jar your memories...
                                            This is PDP42V8 chassis.
                                            Any suggestions would be greatly appreciated.
                                            Angelos...
                                            06-07-2020, 10:10 AM
