Gigabyte board works with GSC capacitors
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Surprisingly this GA-7VKML still worked with six GSC 3300uf capacitors in this condition, driving a Duron 1200
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Gigabyte board works with GSC capacitors
    Hoping for longer life after replacing the GSC crapacitors with UCC KZG salvaged from a dead board
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      nice you have missed some though. what is that one starting to bulge in the middle of the ram. i have seen some gigabyte looking like the first pic to fuck the ram also permanently eventually
      • cods69
        • Oct 2005
        • 92
        That one does look a little deformed on top.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          That one in the middle of the RAM just looks like a deep vent stamp, not really bulging.
          Ludicrous gibs!
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            well ok a memtest would be conclusive
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              More pics
              I think it is deep vent stamping - no sign of bulging
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Also, went through several passes of MemTest with no problems, both memory slots populated
                • Tom41
                  • Oct 2005
                  • 339
                  • England
                  As I mentioned in an earlier 'bad caps irony' thread, caps don't have to be spilling their electrolyte out to have gone bad - they can fail silently and you would never know. On the other hand, you can have a whole load of caps fail inside a PC and it still remains stable - there was a PC at my workplace like that!
                  As a general rule though, when you find bad caps you should replace at least the bad ones as soon as possible. If the other ones are a known bad brand, it may be a good idea to replace those too to save you more work in the future.
                  I can't see any bulging or venting in the second set of pics, where you have replaced the bad caps. I have seen caps that look like they've caved in though, more often than not it's the result of a deep vent stamp (or physical impact, though that often causes similar symptoms to vented caps).
                  You know there's something wrong when you open your PC and it has vented Rubycons...
