Asus PTGD1-LA Grouper Success
  • crash-cyberdrive
    • Jun 2013
    • 62
    • US
    After weeks of reading around posts and searching on the forum I was successfully able to recap this MB I got from a friend bound to the garbage.
    This Is my success story.
    First it was all full of dust, Case fan and CPU fan produced almost no air flow. Than I noticed two of the three rams out of place. Cleaned the case, MB and reseated Ram. To my surprise it powered up and it even posted but no beep
    Shortly after display, maybe 5 min, a lot of garbled characters appeared. Turned off.
    Inspecting the board found 2 Bulged green caps near the ram modules.
    Then took off the ram modules and found this heavy damage on one of the modules.
    This one is a 1gb module, the other was a 512bm module that did not survived either but was not burned like that. The only survivor was a 256MB module.
    I replaced all the caps as described on one post (Thanks Forum)
    2- 6.3v 820uf Near the ram *Rubycon MBZ
    2- 6.3v 1500uf these where replaced with 10v 1500uf *Rubycon ZLH
    5- 16v 1000uf near the CPU ( I think these are for the VRM) *Rubycon ZLH
    16- 6.3v 1000uf all around the board *Sanyo CA
    *I used.
    Since I had no money on the board except for new caps Took off all heat sinks removed all the dried up thermal paste and re-pasted with AS5. BTW the south bridge had very little paste in it.
    Experience- I followed every tip and technique and applied it to my comfort zone to perform the task. The most hard and time consuming part was clearing those holes out of solder and once done all was a breeze.
    I am no novice in soldering or doing electronics but it has been my first multi layered board and of course i wanted it to work. And it did.
    Board with out caps
    Clean South-bridge
    Clean North-brigde
    Recap complete
    A Picture of subject is always Welcome
    Things saved from the e-landfill:
    Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
    Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
    MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
    ViewSonic VA712B - still working on it
    Kindle Fire USB Connector
    MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
    MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
    The list will go on thanks to the people of this forum and many hours of reading.
  • silverHalo
    • Nov 2013
    Re: Asus PTGD1-LA Grouper Success
    Great work on your repair job. I was hoping you might be able to answer a question for me.
    I started working on the exact same MB tonight and didn't realize there were a couple of 1500uF 6.3v mixed in with the 1000uF 10v's when I was removing them. Since they were both the same dimension I didn't realize it until I pulled them all off and now I don't know where one of the 1500uF 6.3v caps are supposed to go. I know that one goes in between the RAM and ATX connector... but the other is a mystery!
    Would you happen to know where the other 1500uF cap goes?
    Thanks!!
      master hoarder
      • May 2008
      • 12175
      In case the OP doesn't answer, I can give you this general info, with which you should be able to repair your motherboard:
      In general, it is safe to replace 10V capacitors on desktop motherboards with 6.3V (since the highest voltage they could filter is 5V).
      Now as far as the capacitance rating - going a little higher with capacitance is almost never a problem. Since you don't know which cap spots had 1500 uF caps and which had 1000 uF, just replace them all with 1500uF.
      In other words, just get 6.3V 1500uF capacitors, and if you don't know whether or not a spot had a 10V 1000uF capacitor or 6.3V 1500uF capacitor, just use a 6.3V 1500uF capacitor.
      • c_hegge
        • Sep 2009
        • 5219
        I often see these boards with the two bulged LTECs around the RAM (and sometimes bad KZGs on the CPU VRM. Being ASUS, though, that's not usually the only thing wrong with them.
        btw, did anyone else find that this page took several minutes to load thanks to all those large attachments?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That shouldn't happen with the server hardware upgrade that Topcat did a little while ago.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            master hoarder
            • May 2008
            • 12175
            ... No wonder my 384 MB Pentium III PC was struggling. I haven't used it for almost 3 months, and thought maybe it really was time to retire it. But no, it's just this particular thread that made it run out of RAM due to huge pics (Firefox was asking for over 600 MB of RAM before forum rescale feature could kick into action to limit the image size).
            This thread is a perfect example of how NOT to add inline images.
            • lti
              • May 2011
              • 2557
              Yes, it was very slow. It's better now.
