Abit VP6:Need help about capacitor connection?
  • supersabre
    • Feb 2006
    • 45
    My board is abit VP6. After i remove the caps, i found that i may damage the board slightly. I guess The distance between the hole and the trace is too close. And i did a bad job of desldering. But i am not sure???
    I am not sure whether the negative of the capacitor EC28(6.3V 1500uF) connects that circuit path.( A connects B???) A is capacitor, B is circuit path
    The circuit path is at the back of the motherboard and Capacitor EC28 is located below the north bridge.
    If anyone has the same board, please let me know.
    Thanks!
    If anyone have the answer, let me know.
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Re: Abit VP6:Need help about capacitor connection?
    Just by looking at the pic, it looks like it does. Its been a while since I've done a cap job so I can't remember. My VP6s are running so I can't double check. If no one can give a definate by Monday, I will pull mine apart (they could use a cleaning anyway) and verify.
    Hopefully, someone will be able to give you a better answer sooner.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • arneson
      • Sep 2005
      • 1267
      I see the solder joints just below that has the tiny traces skirting around them.
      Makes me think the spacing is tight but they would not be connected.
      Don't know for sure though.
      Jim
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i dont think that circuit is connected to the negative lead of the cap.
        the scratch doesnt seem bad
        but you must fix that trace at the top of the -ve hole in the pic
        i think it is difficult but some people here have done such fixes
        must be careful about the heat when the traces are close to the hole!
        • linuxguru
          • Apr 2005
          • 1564
          The trace B in question looks like a ground shield for the controlled-impedance trace above it, probably an impedance-matched clock transmission/delay line. It could be connected to the ground plane at the capacitor pad (among other places).
          Hopefully, somebody who has a VP6 will give you a definitive answer soon.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i looked at a vp6 i got in for recapping.
            the cap pad is connected to the trace
            • Brian C
              • Dec 2006
              • 156
              for motherboard recap, u need high power soldering iron ~ 80W to 100W, best if temperature controlled type.
              Here is my suggestion... on ur problem. Bty, is that trace connected to capacitor pad A originally ?
              Cheers !
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
