Hello all,
I have been a long time reader and occasional poster on this forum, more specifically in the computer display repair subforum. I have repaired lots of them either by recapping/replacing fets.
Now I'm having a bit of trouble with a Woxter i-cube 750 mediaplayer, and could use a little input to get it on its feet again. I got it in non-working condition, the owner could not tell me more than 'it gradually detected the built-in harddisk worse and worse, and now it doesn't detect it at all anymore. The player itself does start up'. It looked to be just a defective harddisk, easy to replace. Lo and behold (of course), when I received the unit it was exactly the opposite: the harddisk (DiamondMax 9 120Gb) was in perfect order, but the player would not startup.
Opening the case it turns out this mediaplayer is basically an implementation of the Realtek RTD-1073 reference design. This is the case with a lot of them out there, such as AC Ryan Playon HD, Mede8er 500X, my Woxter, they are all built around the same mainboard.
Doing some checks with my multimeter, I found out there's a problem with the power circuitry. It should provide 12V, 5V, 3.3V, 1.8V and 1.2V. All but one were present, the 1.2V line was way too low at only 0.5V.
This voltage is generated in a circuit built around a AP1539. Similar to the datasheet it has a smd Schottky diode and 470 uF buffer capacitor on its output Voltage line. I suspect that one of them, or maybe even both, is shot. They are connected in parallel between V-out and GND. With my multimeter on diodetest the diode measures zero Ohm in both directions, so I do not even get a reading of the cap charging. My intuition tells me the capacitor is the culprit, although it does not show any damage or burst vent on top. It may well have taken out the diode in its demise. I haven't replaced the cap yet, but will do so for good measure. I intend to desolder it anyway in order to check the condition of the Schottky diode.
Now I can't determine which Schottky diode is used, and could use some help in identifying it to find a potential replacement in case it turns out to be shot after all. Looking at the marking on top the logo appears to be by Diodes Incorporated. The complete marking is:
|)|| 919
SV4
__ 26
Great things these smd's, very informative...
Does anyone have any idea what kind of Schotkky diode this could possibly be, and which ones are a suitable equivalent? The AP1539´s datasheet suggests a B540 or PDS540 from Diodes Incorporated, but according to their datasheets these have different component markings on top. Are there general rules how to go about when selecting a suitable equivalent?
All info much appreciated!
Regards,
re-atari
|)|| 919
SV4
__ 26
Regards,
re-atari
