Heya!
I acquired this lil board. It is currently not in a functional state. It is in a not-too-bad state of disrepair. It has a 1.3ghz onboard duron
The problem is missing caps and what looks like a transistor or voltage regulator. Missing caps are in the VRM and on the memory side of the cpu. The bigger caps are missing, smaller ones are still there. The second missing component is a voltage regulator/transistor next to the ATX power connection. There are two of then right below the connector, between two caps. The left one is missing in my case. If anybody has this board or a similiar one, i would be really grateful l if you would tell me the spec/model/part number for the missing transistor. The one next to it is an ARL 431 PF81Y. I have no idea what the board does, as i currently have no intention for powering it on.
Any help strongly appreciated!
The problem is missing caps and what looks like a transistor or voltage regulator. Missing caps are in the VRM and on the memory side of the cpu. The bigger caps are missing, smaller ones are still there. The second missing component is a voltage regulator/transistor next to the ATX power connection. There are two of then right below the connector, between two caps. The left one is missing in my case. If anybody has this board or a similiar one, i would be really grateful l if you would tell me the spec/model/part number for the missing transistor. The one next to it is an ARL 431 PF81Y. I have no idea what the board does, as i currently have no intention for powering it on.Any help strongly appreciated!
Put the caps back in, all 6.3v 3300uF G-Luxons, just for a test. Also, the missing transistor must be a PNP, since the one next to it (connected to it) is an NPN. It's marked as ARL 431 PF58Y
