Hard to find Cap
  • Bishop
    • Apr 2009
    • 99
    Hard to find Cap
    This cap came out of a Dehumidifier. I don't have the facility to test it, so I'm looking for replacement.
    This is the label information:
    CBB65 17uf -+5% 250VAC 50/60Hz C.P1
    Plant Oil E243410
    TONGLING CITY, TONGLING
    I contacted them by email and they do have the correct Cap, but the minimum order is 1,000.
    The strange thing is that it has 3 post on top and is blue in color.
    There was a total of 8 wires connected to the 3 terminals
    1 wire on 1, 4 wires on the next, and 3 wires on the third post.
    I keep finding a Cap with only 2 post on top.
    I'll try to post a pic
  • Bishop
    • Apr 2009
    • 99
    Re: Hard to find Cap
    1
    • mariushm
      • May 2011
      • 3799
      The pictures are useless, too blury.
      Use the Macro mode of your camera if it has any, or put the camera on some support before snapping pictures so that your hands won't shake (and play with the distance between camera and capacitor)
      • Bishop
        • Apr 2009
        • 99
        I tried to make a better image but my camera blurs up close
        I did type the information on the label in my first post
        CBB65 3 terminals 17uf 250vac
        The cap is 68MM high and 50MM wide
        • sofTest
          • Aug 2008
          • 361
          It looks like a dual AC motor capacitor. Something like this. They usually have dual uF-rating, not only 17uF like this one. Might be 2x17uF? A 25-15 uF might work, if it is easier to obtain.
          Be a mensch
          • gilly1984
            • 751
            Pull camera away a bit, as long as its focused people here will be able to help.
            Do NOT touch heatsinks when testing for voltages as they may be LIVE!
            • Toasty
              • Jul 2007
              • 4171
              CBB65 isn't the model number, it's more like the series. These come in a variety of terminations and values.
              One of those legs may go to the shell and be ground. Several I've seen are exposed metal cans and would ground through the strap that ties them to the chassis. This one has a polyvinyl wrapper. Does one of them read 0 ohms to the metal case under the blue plastic wrap?
              What make & model dehumidifier is it out of? Probably easier going that route.
              Please give all the numbers, line-by-line, or a clearer photo.
              Why do you suspect this cap?
              T
              veritas odium parit
              • sofTest
                • Aug 2008
                • 361
                Data sheets for standard Cinco capacitors can be found here.
                Neither physical size nor value fits any of the standard listed. I'm guessing that this is a custom capacitor, hence the large order quantity. I agree with Toasty, the manufacturer of the dehumidifier might be the way to go, if exact match is required.
                Be a mensch
                • Bishop
                  • Apr 2009
                  • 99
                  Here's all the information on the Cap in order:
                  (TX) CBB65
                  17uf-+5% SH
                  250VAC 50/60 Hz
                  CQC C.P1 40/70/21
                  CQC03002005280
                  DVE PLANT OIL
                  EN 60252 132314
                  E243410
                  ANH TONGLING CITY TONGLING
                  ELECTRIC CO.LTD
                  It's a Sunbeam DHC-20M
                  S# 20050620323
                  • Toasty
                    • Jul 2007
                    • 4171
                    Again -
                    >>One of those legs may go to the shell and be ground. Several I've seen are exposed metal cans and would ground through the strap that ties them to the chassis. This one has a polyvinyl wrapper. Does one of them read 0 ohms to the metal case under the blue plastic wrap?<<
                    Also, it looks like Sunbeam is out of the dehumidifier business. The manufacturer of ones for them through their subsidiaries, that were marketed 4+ years ago, is also gone.
                    Drag to curb. Get new one from next Chinese manufacturer.
                    T
                    veritas odium parit
                    • Toasty
                      • Jul 2007
                      • 4171
                      Also, again-
                      What makes you suspect the cap? They usually fail with a *bang*.
                      Symptoms?
                      T
                      veritas odium parit
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        is it shorted?
                        if so the compressor would hum and trip its limit switch.
                        • PaulMc
                          • 5
                          There should be a schematic somewhere on that unit. Scan it and post it if you can.
                          It looks as though you have a dual capacitor for the compressor and a fan motor. Usually one side will be a lower capacitance but yours only seems to say 17 uf. It's hard to tell from your pics, is that a sheen of oil on top?
                          A lot of these units get tossed because the compressor is suspect when something simple has gone wrong, like a defective water level switch. A stuck compressor can sometimes be broken loose with a start kit.
                          • Bishop
                            • Apr 2009
                            • 99
                            The Cap does not seem to be leaking anything, in fact it's very clean.
                            I've manage to fix most things I've worked on by simple cap replacement. This unit has two caps, I replaced the cap that went to the units fan control, it only cost $4. Before I replaced that cap the fan ran all the time even with the control knob turned off. But after I noticed the compressor was not working and I didn't have the correct meter to test this cap, I went looking for a new one.
                            So the cap with three terminals was had to find, thats what brought me back to this forum.
                            I'll breakdown the terminals on top which might help.
                            The termnal clockwies from 9:00 is a single clip with "HER" stamped on it.
                            The terminal at 12:00 has three clips and has a "L" stamped on it.
                            The terminal at 3:00 has four clips and has an "N" stamped on it
                            This single Cap had Nine wires connected to it, including the live AC wire to the compressor.
                            • Bishop
                              • Apr 2009
                              • 99
                              What is a compressor "Start Kit?"
                              • PaulMc
                                • 5
                                Google refrigerator hard start kit and you'll find several examples. It's an extra capacitor parallel to the run capacitor during the start up to increase the starting torque. A relay drops the start capacitor out of the circuit after the amperage drops close to the normal FLA.
                                Your terminal markings should stand for neutral, line and hermetic. You could take your capacitor to an appliance shop that sells parts and ask them to check it for you. Did you find a schematic in the unit?
                                • Bishop
                                  • Apr 2009
                                  • 99
                                  No Wiring plan and The original papers cannot be found after we moved.
                                  I'll look up the start kit, it sounds interesting
                                  • Bishop
                                    • Apr 2009
                                    • 99
                                    I ordered a Start Kit online yesterday, it should ne here by the weekend
                                    Only time will tell.....
                                    • Bishop
                                      • Apr 2009
                                      • 99
                                      Sad to say the start kit didn't help.
                                      I disassembled the dehumidifier and saved what I could use elsewhere and ordered a new unit.
                                      Many thanks to all....
                                      • PaulMc
                                        • 5
                                        Sorry to hear it wouldn't start. Hope you were able to get some usable parts from it.
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • danielgerman681
                                          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                                          by danielgerman681
                                          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                                          08-27-2025, 01:17 PM
