GA-965P-S3 doesn't boot even after recap
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    For GA-965P-S3 REV1.0 (Doesn't apply to ga-965p-ds3 which has solid caps.)
    The mainboard had history of overheating, the video card is with passive cooling and SB got very hot, this could speeded up the failure.
    Firstly the Intel SATA ports failed first and the HDD controller reported intermittent errors in event viewer and PC sometimes locked. Temporary it could be fixed by plugging HDD into GSATA ports. But after couple months the PC didn't boot. Inspected the board visually and found two blown caps(didn't check the brand)
    Replaced the 2 blown caps(DEC11, DEC12) 6.3V 3300uF. After that PC could be booted but only after powering on/off 2 times everytime. Now again it doesn't boot. The symptoms: the CPU cooler works but no POST beeps - nothing. What else could be at cause?
    Other caps on board:
    16V/1500uF Rubycon (MBZ) 4x
    6.3V/1000uF Nichicon (HM(M)) 20x
    16V/470uF KZG 1x (gigabyte - why put different brand for 1 cap?)
    10V/100uF TEAPO (A3) 7x
    16V/100uF can't see ends with E...con (E67F) 1x
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: GA-965P-S3 doesn't boot even after recap
    Nichicon HM with 2001-2004 date codes are defective due to manufacturing goof.
    Nichicon Date Codes.. in H0322 .. the "03" = year 2003 [and the "22" = week 22.]
    - Need to replace all of them.
    Chemicon KZG are bad and often don't bloat.
    Evercon are bad but a small one like that is less likely to be the problem than HM or KZG.
    - Probably don't -need- to, but I'd replace it anyway.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You could have two or three Gigabyte same model & revision motherboards from the same factory and almost every cap can be different between them.
      Just depends on what they had that day for that spec cap.
      About the age your board is Gigabyte was using KZG, HM, and MBZ interchangeably.
      What you got was luck of the draw.
      - Dr Seuss
      • RJARRRPCGP
        • Jul 2004
        • 6301
        What processor is on that board?
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • otoluk
          • Feb 2009
          • 84
          • Latvia
          Thanks.
          Processor is Pentium D or something. The board is year 2006. Nichicon HM date code A0630
          I will replace 6.3V/3300uF with Rubycon when they arrive and replace chemicon and evercon. Let's see.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            its not the board that has a history of overheating, it's the processor. Pentium D is one of the most terribly overheating processors in the history of desktop processors. get a better heatsink on there, clean them up (heatsink bottom and cpu top), and put some artic silver on there (fine, thin layer, spread as thin as you can get it)
            were DEC11/12 near the CPU?.....the heatsink might not be transferring enough heat off it and the chip itself is overheating the board, and thus the caps (why those 2 probably originally bloated)
            go ahead and replace the KGZ's, thats your best bet, but I would also try an alternative CPU if you've got one, those D's draw some serious power and require some higher voltage, of a cap blew and was blown for a long period of time, it might have put too much current through the cpu vrm
            oh yeah replace the nichis too, I like Sanyo's, but Panasonics are just as good
            • otoluk
              • Feb 2009
              • 84
              • Latvia
              Yeah but North and South bridges were heating a lot too and the passive cooled VGA(one bad cap on it also) maked it even worse. I salvaged the broken PC at my workplace so nothing to lose. The bad caps was around CPU of course. Reapplied the thermal paste it was hardened like a brick, almost lifted the NB .
              Is there a dealer for Rubycon in Europe? I just calculated for replacement of all caps it costs 40$ locally. I just don't seem comfortable to order from badcaps the caps then will travel - Asia->USA->Europe
              • RJARRRPCGP
                • Jul 2004
                • 6301
                Some Conroes seem to be the same, too.
                My E4500 will get hot easily with a stock heatsink. And the E2180s seem worse.
                Makes me kind of amazed that I can OC it to where I am.
                Arc A770 16 GB
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  check your voltages, make sure your PSU isn't putting too much juice to it. it would explain why it not only runs hot, but why you can overclock it well
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    In Europe that I know of there is RS Components.
                    There is also a member here [Big Pope] that sells Samxon out of Hong Kong.
                    You can PM him.
                    - Dr Seuss
                    • otoluk
                      • Feb 2009
                      • 84
                      • Latvia
                      Resoldered all caps except Nichicons, there are too many of them and one naughty cap pissed me off. At first it didn't boot so I thought that I failed but after CMOS reset it was back to life. Now it works again .
                      There was one cap witch I couldn't unsolder correctly. It has two alternate mounting holes and it was impossible to extract it. Used 50W iron and 240°C temp is it not enought? Ended up with this.
                      After one week of burn-in there is only one problem remaining. I can't use RAM in dual channel mode the board reboots in endless cycles.
                      What is causing this?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        240°C isn't even close to hot enough. I always use at least 450°C
                        • otoluk
                          • Feb 2009
                          • 84
                          • Latvia
                          my mistake I wanted to spell 450°C just miscalculated . But the soldering iron can't push higher than that maybe I should look for chisel tip for iron. Neverless soldering the cap on side did the trick so for a now let it sits like that.
                          Still looking what causes the dual RAM fail.
                          • otoluk
                            • Feb 2009
                            • 84
                            • Latvia
                            Got it! The problem with the dual channel RAM is only when Intel QST is enabled. Strange that CMOS reset doesn't clear that, I can boot only when RAM module is set in slot3 so the QST disables automatically and then disable it in BIOS. Tried different bios and the same problem.
                            How this QST works? What interferes with it?
                            • privato89
                              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                              by privato89
                              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                              Let's begin:
                              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                              03-26-2024, 06:37 AM
                            • hinisa
                              Xiaomi router freezes at boot after re-capping
                              by hinisa
                              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                              07-08-2023, 05:58 AM
                            • Luke Anders
                              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                              by Luke Anders
                              A few details about the laptop itself:
                              Name: Lenovo Legion 5
                              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                              BIOS Version: GKCN60WW
                              EC Version: GKEC65WW
                              Serial Number: PF39AQ7Z
                              Board Model: NM-D562 Rev 3.0
                              RAM: 16GB Installed, DDR4 (brand new)
                              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                              I bought this laptop recently from eBay as a faulty device....
                              10-12-2024, 05:13 AM
                            • NolesFan
                              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                              by NolesFan
                              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                              10-24-2024, 06:36 PM
                            • torchzack
                              Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                              by torchzack
                              Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                              I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                              Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                              08-28-2023, 07:42 AM
