Re: Intel D945GCLF Bloated Samxon GC due to overheating
You're totally right about MCZ not taking abuse well at all.
The electrolyte in very old Panasonic FJ (like pre-2005) starts to congeal towards the bottom. I might post pics of this some day. They still might work perfectly fine, but this is just something to consider.
the intel fan has a lifetime warranty - just so you know.Leave a comment:
Replacing a Rubycon MCZ at C47BV with a Panasonic FJ might look pointless, but MCZ is rated only for 2000h and they often fail in high-heat, high-ripple locations. FJ is far more durable in such applications, and I got double the capacitance in the same 8mm diameter. We'll sign how it goes, but I anticipate no problems. Also available in 8mm are Panasonic FJS, FL and Rubycon ZLH.
Cases like this make me nervous about using ultra-low ESR Samxon electrolytics, especially given the fact that their entry level low ESR electrolytics are very unreliable. I suppose it's possible that their QC testing isn't the best, which is why good batches of Samxon and bad batches of Samxon exist.Last edited by Wester547; 10-24-2015, 09:18 AM.Leave a comment:
Replacing the original fan was one of the first things I did to my board, along with the heatsink.
So it's now running with it's third fan
I've always run the fans with a Zalman power adapter at such a low RPM that I can't hear it...Leave a comment:
Yup, it runs at ~4500 rpm so the bearing probably wears out quicker. Mine wasn't used 24/7, so the original fan is still intact, but I'd probably go with an NMB or similar ball-bearing fan when I replace it.Leave a comment:
i was going to replace the 3300uf with this:
http://uk.farnell.com/wurth-elektron...ial/dp/2466521
I left the single polymer next to the CPU alone, since it probably doesn't see much ripple from the 2W Atom. However, I might investigate whether it's worth populating some of the empty locations next to it in a future recap.Leave a comment:
The Samxon ULR polymer caps I used in my original post here have hold up well for over 4 years now.
I never replaced the original Samxon GD 3300uF cap or the Rubycon MCZ 820uF cap next to it by the memory and it's still working fine like this over 7 years later.
System is still in use 24/7 as my firewall with only a tiny silent fan on the chipset heatsink.
The fan I have had to replace though, those small spinners are not very reliable...
Now I've been using a Noctua NF-A4x10 FLX 40mm fan for a little over 2 years and it started making noises.
It has a 6 year warranty though so I should be ok, right now I just flipped it over which made it silent.
I've learnt the hard way that sending in things for RMA that are not 100% dead is uselessLeave a comment:
i intend to put some poly's on my one soon,
http://uk.farnell.com/wurth-elektron...ial/dp/2466521Leave a comment:
Some of the smaller electrolytics appear to be bypasses for linear regulators - there's a risk of instability if the ESR is too low at those locations. For those that are used in switching converters, polymers would be a good choice - but the values have to be determined by trial and error, e.g. is 820uF/6.3 sufficient to replace the 3300uF/6.3, 1000uF/10, 820/6.3 electrolytics, and so on? Since I had only one board to play with, I didn't want to risk too much by trial and error.
(I also forgot to mention that C20BV, the 3300/6.3 at the corner of the board is a *bear* to replace. It's sitting on one or more copper planes, with a thick copper inductor nearby conducting heat from the planes. Add to that the higher melting point of Pb-free solder, and it's pretty hard to get the cap out, clear the through holes of solder without damaging them, and install the new capacitor without shorting the pad(s) to one of the ground planes - the isolate ring between the pads and the ground plane seems to be only 10 mil or so, so it's rather easy to create bridged shorts to ground. If it doesn't look bulged, it may be prudent to leave it alone. The only reason I replaced it, is because it was a Samxon.)Leave a comment:
why not just 100% polymod the whole board? there arent many caps to change.Leave a comment:
Other replacements (for future reference):
C86BV, C162BV: Samxon GC 1000uF/10V replaced with Rubycon ZL 1500uF/6.3V/10mm
C47BV: Rubycon MCZ 820uF/6.3V/8mm replaced with Panasonic FJ 1500uF/6.3V/8mm
C20BV: Samxon GD 3300uF/6.3V/10mm replaced with Nichicon HM 3300uF/6.3V/10mm
Everything else (mostly 470uF/10V Nichicon VR and 100uF/25V Samxon GS) is stock - though it might not hurt to replace C110BV and C46BU next to the Southbridge and PCI slot also. I didn't have 470uF in 6mm diameter, so I left them alone.
I ran Memtest86 on it to check stability, and it's rock stable and everything is cool as a cucumber. BIOS HW monitor reports CPU temperature as 47c, which is fine. This is a great platform that has been ruined by bean-counters looking to save a few cents - it's an EM64T Atom that destroys everything else (except maybe a Dothan Pentium M) on single-threaded performance at the same clock.Leave a comment:
Taicon is an Taiwanese associate/subsidiary of Nichicon, Japan. Their series are generally a subset (and similarly named) of Nichicon's. I haven't actually seen a failed Taicon cap yet, including the HD, though it's entirely possible that they fail in hot and high ripple-current locations like VRM outputs (where MCZs, KZGs, KZJs, etc. also die like flies). I have also used 16V-rated Taicon HD in SMPS recaps without a single failure in about 9 years - they seem to be similar in size and specs to NCC KZE, another series in which I haven't encountered a single failure.
9 years of daily use or 24/7 use is impressive, but it would be understandable if the power supply is cooled and ventilated well (even crap brands last a long time in power supplies that run very cool). The fact that they survive on the +12V output is also understandable. I believe you correctly pointed out a while back that the higher voltage retards or at least prolongs the electrolytic dissolution (the failed Taicons on those motherboards were in the VRM output). The other series from Taicon seem to be fine and only seem to fail under discolorating levels of heat. I'd guess they're about the same in quality as the good series from Samxon.Last edited by Wester547; 04-13-2014, 12:51 PM.Leave a comment:
Taicon is an Taiwanese associate/subsidiary of Nichicon, Japan. Their series are generally a subset (and similarly named) of Nichicon's. I haven't actually seen a failed Taicon cap yet, including the HD, though it's entirely possible that they fail in hot and high ripple-current locations like VRM outputs (where MCZs, KZGs, KZJs, etc. also die like flies). I have also used 16V-rated Taicon HD in SMPS recaps without a single failure in about 9 years - they seem to be similar in size and specs to NCC KZE, another series in which I haven't encountered a single failure.Leave a comment:
I'd say Samxon is good quality as well (it may be hard for many to trust Chinese manufactures given that most brands suck). A couple of crap series does not make them crap. Adhering to that mindset, Chemi-con is no good.Leave a comment:
Read what I posted in my original posts above, the lifetime is as expected from the capacitors datasheets.
Apple computers fail in the same way with Rubycon capacitors, it does not mean there is anything wrong with the capacitors there either!
In my case I replaced the Samxon GC caps with Samxon ULR polymer caps, it's been running fine like that for another 3 years now...Leave a comment:
I like the look of Taicon also. Seen several Taicons still perfectly fine and in spec while all surrounding CapXons had blown their vents out.Leave a comment:
They are good quality for Chinese caps. While some don't like them, i have only encountered 2 failed series so far: GF and GC. This site does not carry any of them.
Also some people regard Taicon as a bad cap brand. Well, Delta uses them with very few issues, and they're very cheap, and certainly better than no-name Chinese ones. I use Taicon caps to recap low-end PSUs and they seem to hold up fine.Leave a comment:
Aren't Samxon caps being sold by this same website as "good quality"?Leave a comment:
Samxon capacitors are low quality: after I did a lot of research and analyzed a bunch of failed hardware sporting them I wouldn't even rate them so-so. Super high failure rate, poor filtering.
Interestingly enough, I had an intel atom board which came OEM with samxons (along with other bad caps)-- I replaced them with some nice rubycons and ELNAs.Leave a comment:
And I thought only dodgy Chinese component suppliers pulled that trick.Leave a comment:
by VenDell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal
2 Photos - CPU Overheating to 100°C
by NagyeszI have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
Should I inject voltage somewhere, or should I replace the ICs right away?
So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
by ktmmotocrossHave this PS5 Slim with no video, HDMI connector was horribly butchered. but after replace i have no video. diagnostic said APU was overheating and now not responding,
checked fuses and all are good
any hint?...07-24-2025, 02:12 AM -
by TomyleeHi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
Here's what I've observed:
All ribbon cables are properly connected
Battery is present and in good condition
No reaction even with screens disconnected
There's a visible burn mark / overheating sign on the metal shield, right above the CPU
I’m suspecting an issue with the CPU, PMIC, NAND, or a power...3 Photos -
by chth96Hello.
I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...-
Channel: General Capacitor Questions & Issues
- Loading...
