Recapping GA-M55plus-S3G using lower rated capacitance
  • rhan101277
    • 10
    My computer has failed for about a week now. I tried power supply replacement after finding that my computer would turn on then immediately off.
    After more troubleshooting and removing peripherals, I found that the computer would not stay on with the 12V ATX 4pin connected. My capacitors were bulging and they were shorted.
    I replaced (5) 3300uF capacitors 6.3V rating
    with
    (3) 1,000uF capacitors 10V rating
    (2) 1,000uF capacitors 16V rating
    While I know decreasing the capacitance is not recommended my computer has been stable for an hour. I plan on getting a new mobo, CPU barebones at the end of next month.
    Less capacitance means less time that the capacitor can hold the charge, these ones are meant to keep the power going to the CPU stable correct?
    I have a degree in electronics but it has been so long since I have had to use any of those skills.
    What exactly can using a lower capacitance rating do?
    Not be able to supply voltage for a certain duration when its needed?
    Discharges to fast?
    Any help would be appreciated, I have a decent back ground, but most I have learned about caps were how they worked in power supplies to reduce ripple.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Recapping GA-M55plus-S3G using lower rated capacitance
    There is a large chance that they used so high capacitance values just to get the required ESR. Capacitor technology has progressed a lot in the past few years. If the board runs fine there's nothing to worry about.
    A working TV? How boring!
    • Scenic
      o.O
      • Sep 2007
      • 2642
      just for reference..
      http://bambooz.pytalhost.net/badcaps/M55Plus-S3G.jpg
      those 5 caps you mentioned seem to be on the CPU VRM output (the 5 black ones with the X vent above the CPU socket)
      • rhan101277
        • 10
        Those are the five I had to replace. So they don't help control Vcore? edit: I think I figured it out, they smooth out the Vcore and they are in parallel
        • rhan101277
          • 10
          Also i was thinking from school that capacitors that are in parallel add up, like resistors in series do. I remember that being different
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            I am concerned with that much difference
            you're replacing 16500uf with 5000. that bothers me. but if it works fine, it might continue to, for now
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Bulk capacitance is for smoothing transients but that is -NOT- why they used 3300uF caps there.
              They used those caps for low ESR and high Ripple ratings.
              It's doubtful 1000uF caps have low enough ESR to remove the ripple [means possible unstable system, reboots, BSOD, corrupted data, etc.] and also doubtful they have high enough of a ripple rating to not overheat. [means very short life for the caps.]
              Mann-Made Global Warming.
              - Dr Seuss
              • rhan101277
                • 10
                Well it is just a quick fix. These caps came from a spare PC power supply I have so they should be good for ripple and heat.
                6 hours uptime now, with graphics intensive games occasionally. I am going to order the proper size.
                • rhan101277
                  • 10
                  I find these caps are made by <BH>, maybe made in china. I can't find any accurate specs on them. I am going to order some rubycons from here on Friday.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    There's a good reason why you can't find specs. They won't last long. I thought you used better ones.
                    Good idea.
                    • Rulycat
                      • Apr 2010
                      • 724
                      • United Kingdom
                      I remember seeing some BH caps in a CIT PSU. It was £16 which kind of tells you how good those capacitors are.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        BH is properly BH Pro-An. They are rebadged KOME brand.
                        Both made by Pro-An Electric Co. out of Hong Kong.
                        http://www.proan.com.hk/index.php?op...d=62&Itemid=76
                        And yes, they are crap..
                        - Dr Seuss
                        • rhan101277
                          • 10
                          I am not sure if these are 10mm tall or 25mm, the 3300uF Rubycon only come in 25mm tall.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            A 3300uF cap must be tall, atleast 25mm if only 10mm thick
                            Just measure it but in the picture linked by Scenic they look to be 25mm tall to me.
                            I borrowed this pic from Newegg, seems that 25mm is correct.
                            Anything is ok so long as it clears the heatsink you use...
                            Btw, I'm surprised the thing works at all with the caps you put in, for sure it will not have a long life before it cooks those poor capacitors
                            • rhan101277
                              • 10
                              24hr no cooking yet, still getting correct ones though
                              • rhan101277
                                • 10
                                Replaced the five short term fix capactors with.
                                Nichicon HZ 6.3v 3300uF 10X25mm - Ultra low ESR
                                Nichicon Part number: UHZ0J332MPM
                                Rated Voltage: 6.3v
                                Rated Capacitance: 3300uF
                                Capacitance Tolerance: 20%
                                Temperature Range: -25 to 105C
                                Rated Ripple Current: 4690
                                Diameter: 10mm
                                Height: 25mm
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Congrats!
                                  You are now allowed to have a warm fuzzy.
                                  - Dr Seuss
                                  • zooma.tech
                                    • Aug 2013
                                    • 11
                                    • russia
                                    check this circuit in the photo , and remind the 3 channel are the same
                                    *substitute the same values of components
                                    • luke10050
                                      • Mar 2013
                                      • 209
                                      wait that means instead of using 5x3300uF caps you could use 2800uF caps with similar ratings with the sixth one in?
                                      • tmiha71
                                        • Apr 2010
                                        • 130
                                        with
                                        When you had improvements with this low capacitance caps, and higher ESR than original (dead), you should continue to try to poly mod that board :-))...
                                        Keep that capacitance, and lower ESR, something 820uF, or 1000uF from any manufacturer...
                                        Only suggestion :-))... /Accept for to late advice../
                                        Note about PSU caps, usually they're at least one notch better, or at least should be, than mobo caps - they're alone, and sometimes they had to swallow more than 10A...
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • DrewPhillips
                                          SFX PSU - Need High Current on 3.3V & 5V Rails?
                                          by DrewPhillips
                                          I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                                          The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                                          02-18-2025, 01:03 PM
