IBM 8187 P4 2.8Ghz
  • vintageibm
    • Oct 2009
    • 15
    IBM 8187 P4 2.8Ghz
    I picked up an IBM 8187 2.8Ghz 512 40gb for $4.97, from a scrapper. It was sold at not working. These IBM systems have some kind of plug in (when you plug it in the wall) self test, it will fire up the system, the hdd will spin up and all fans, basically a full power up. On a working system, it will shut down until you power it on. However on this system it will just stay running and not answer to the power button and will display no video. It only has one visible bad cap, a 10V 1500UF next to the AGP slot with a bulged top. There is two more of the same caps but look just fine. I ordered new ones though here to replace them.
    My question is do you think it's to late for the that board or can that one cap cause no video and no post/plug in test? Do I need to replace all the caps from that brand? Or just replace all three of those 10V 1500uf's? Or just replace that one bad one? Also with desoldering, do you recommended a braid/wick or a sucker.
  • brethin
    • Dec 2008
    • 1907
    Re: IBM 8187 P4 2.8Ghz
    1 cap can go and cause the failure but normally when 1 cap goes others are soon to fail as well. Without knowing what the caps are (make/series) it will be hard to give good advice on which ones to replace besides the failed one. Post some pictures of the board and closeups of the caps.
    • vintageibm
      • Oct 2009
      • 15
      Hope this helps... The bad cap is at the end of the AGP slot
      • c_hegge
        • Sep 2009
        • 5219
        Those caps are Chemi-Con KZG. They often fail with no visible signs. I see three sizes there. 10V 1000uF, 10v 1500uF and 6.3v 2200uF. Use these to replace the 10v 1000uF cap (yes, 10v and 6.3v caps can be used in place of each other), these for the 10v 1500uF caps and these for the 6.3v 2200uF caps.
        The other caps are Rubycon MBZ and Sanyo/OSCON SEPC. They are good caps and can stay.
        • vintageibm
          • Oct 2009
          • 15
          OK I just placed the order for other caps. They should be on there way. I stuck with the same voltage 10V, just because I have been told "Replace with the same" over and over again.
          Now for the desoldering part, what's the better way a wick/braid or a sucker?
          • bigbeark
            • Jan 2010
            • 661
            If you search "IBM" on these forums you will find people have had trouble recapping these particular boards.
            The existing solder on the board is nasty stuff that doesn't flow easily. Be sure to add new solder to the old when attempting to remove the caps. I would use the pin method to clear the holes. The holes on these boards are small and hard to clear.
            Be really patient. I have only wrecked one board, and it was one of these. The traces are very fine wire and the laquer coating is very thin. Very easy to inadvertently damage the traces with your tip.
            Replace the damaged cap and see if you can get the board to BEEP by leaving the RAM slots empty.
            I am not a fan of these, they can be quick but they run very HOT like 67C with the stock cooling. The BIOS is quite limited and you get to it with F1 or F2 - can't remember.
            Does the board start all by itself with fans turning at high speed?
            That is NOT a good sign.
            Best of Luck with this. Keep us posted.
            • vintageibm
              • Oct 2009
              • 15
              Thanks for the good info, I collect the 1st IBM PC the 5150, So I thought I would add IBM's last PC before they sold to Lenovo.
              I have one system that works fine, but for how long I don't know. This one I picked up because of the price and having bad caps, I have replaced caps in LCD's ect. No problem, I thought just stick in some caps. But after looking this form over I thought maybe it would turn in to a PITA.
              I only have these for collection purposes, as much as I hate to say I am not a fan of IBM's later stuff either. Every one I have owned has either died crashed or failed in someway, I have a netvista for a media PC and it cooks the hardrive (121F) and the system runs very hot.
              Ya the system runs the fans at full speed (as soon as you plug it in) until you unplug it. It dose not responded to the power switch.
              It will keep ya all posted when the parts get here...
              • vintageibm
                • Oct 2009
                • 15
                Hello all, I replaced the one bad cap and it has no effect on the MB at all. Any more ideals before I waste time and caps replacing the other ones?
                The soldering is not bad at all, I just heated one leg titled it did the same to the orther and then used some wick on both sides of the hole and it came perfectly clean
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Yes.
                  Replace the rest of the KZG.
                  As was said; KZG fail without bloating.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    replace the smaller one on the other side of the agp latch.its always cooked.for a quick test replace it and the bulger.if it posts finish the job.
                    • Logistics
                      • Apr 2007
                      • 721
                      I just picked one of these 8187's up in fully working order with the original IBM image of XP as well as an 8183 with the same configuration.
                      It seems to me that the first thing that should have been checked was the power-supply. In my unit the PSU is an Acbell (sp), and I wouldn't trust that much.
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • RetroComputingGrotto
                        Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                        by RetroComputingGrotto
                        I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                        As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                        What is your advice/opinion on whether or not on old(er)...
                        04-03-2024, 08:30 AM
                      • chth96
                        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                        by chth96
                        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                        Since then, This AC/DC adaptor have been out of order.
                        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                        And Is there any possibility that it will suddenly explode as well as to be out...
                        12-03-2023, 04:40 AM
                      • psyduck
                        Conformal coating on Samsung U32D970 monitor PSU, do I need to replace after repair?
                        by psyduck
                        I have a Samsung U32D970 monitor from 2015 I pulled out of the bad hardware pile that turned on and then turned itself back off after a few minutes of use and refused to turn back on. The PSU has part number BN44-00786A, and I found a couple posts about one that had blown with damage to the MOSFETs and PWM controller - but nothing about intermittent failures. I started a new thread and said that I would refresh the solder joints on the board to see if it was just a bad connection and possibly replace the PWM and PFC ICs. I then asked what my next course of action would be after those steps. I...
                        11-27-2023, 06:56 PM
                      • disorder
                        HP 2311 display, 3.3v regulator fried, need help to replace
                        by disorder
                        hello,
                        i have a hp display 2311 to repair, totaly dead
                        on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                        i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                        thank you
                        07-27-2025, 04:34 AM
