Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
  • kiddznet
    • Jul 2010
    • 176
    Would a bad Ethernet Controller stop this board from posting?
    Please have a look
    If anyone has one of these boards can you please identify the missing cap values?
    If you have a board like this can you please identify the missing cap values thank you
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • seanc
    • Nov 2008
    • 1319
    Re: Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
    I think I have one of these in the rubbish pile at work - blown caps, it's not worth repairing to me.
    Will check Monday.
    I think the missing component in that location is normal.
    • kiddznet
      • Jul 2010
      • 176
      Thank you seanc
      Actually, I was referring to the surface of the ethernet controller, does it look like it may have got hot?
      • seanc
        • Nov 2008
        • 1319
        Oh right, I can't tell it looks like a shadow.
        You're missing a hell of a lot of caps, that's probably one reason why it's not starting.
        I can't see any CPU mosfets either... hmm.
        • kiddznet
          • Jul 2010
          • 176
          LOL
          No it wouldnt post before the caps came out.
          • seanc
            • Nov 2008
            • 1319
            Possible that the bad caps have caused a mosfet to short. Got a multimeter handy?
            • kiddznet
              • Jul 2010
              • 176
              Multimeter at the ready suh!
              Getting a little late in Blighty?
              • kiddznet
                • Jul 2010
                • 176
                Another question if I may..Ive a Gigabyte board that has a noisy Northbridge gigabyte fan
                Would the heatsink thats in the photo above be an adequate replacement?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  The LAN IC looks fine.
                  Not likely a bad one would prevent booting. Could, but not likely.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I have a Ford Granada on the left and another Ford on the right.
                    Will the Granada's transmission fit the mystery Ford?
                    Usually easier just to get a new fan.
                    http://www.allelectronics.com/make-a...20/Fans/1.html
                    - Dr Seuss
                    • seanc
                      • Nov 2008
                      • 1319
                      Here you go:
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Every time I see a motherboard with a heatsink like that, I always replace it with a bigger one. Those heatsinks provide very little cooling and are inadequate for just about all chipsets other than those which run so cool they don't need a heatsink at all.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Overkill.
                          Most modern chipsets are under 10 watts.
                          http://en.wikipedia.org/wiki/List_of...ore_2_Chipsets
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Originally posted by PCBONEZ
                            Overkill.
                            ERROR in my choice of reference.
                            Whoever filled in that wiki used idle watts.
                            That's not to say they have THAT much more TDP.
                            Chipsets are under 30 watts and CPU's in servers with TDP twice that often use fan-less heat-sinks.
                            Fancy coolers on chipsets are mostly marketing [at least for Intel chipsets. - AMD, VIA, and nVidia may be power hogs.]
                            Anyway - For reference here are the TDP's for Intel.
                            IOH:
                            X58: 24.1 W
                            MCH:
                            (Note: Idle Power is based on a typical part in system booted to Windows OS with no background applications running.)
                            X48: 26.5 W, 12.3 W idle, with 333 MHz FSB
                            P45: 22 W, 9 W idle, with 333 MHz FSB
                            G45: 24 W, 9 W idle, with 333 MHz FSB
                            P43: 22 W, 9 W idle, with 333 MHz FSB
                            G43: 24 W, 9 W idle, with 333 MHz FSB
                            X38: 26.5 W, 12.3 W idle, with 333 MHz FSB
                            P35: 16 W, 5.9 W idle, with 333 MHz FSB
                            G35: 28 W, 11 W idle, with 333 MHz FSB
                            Q35: 15 W, 6.5 W idle, with 333 MHz FSB
                            G33: 14.5 W, 5.75 W, with 333 MHz FSB
                            P31: 15.5 W, 7.6 W idle, with 266 MHz FSB
                            G31: 15.5 W, 7.4 W idle, with 266 MHz FSB
                            G965: 28 W, 13 W idle
                            Q963: 28 W, 13 W idle
                            Q965: 28 W, 11 W idle
                            P965: 19 W, 10 W idle
                            975X: 13.5 W
                            955X: 13.5 W
                            945G: 22.2 W
                            945GZ: 22.2 W
                            945P: 15.2 W
                            945PL: 15.2 W
                            925XE: 13.3 W
                            925X: 12.3 W
                            915G: 16.3 W
                            915GV: 16.3 W
                            915GL: 16.3 W
                            910GL: 16.3 W
                            875P: 10.1 W
                            865G: 12.9 W
                            865GV: 12.6 W
                            865PE: 11.3 W
                            865P: 10.3 W
                            845GE: 6.3 W
                            845PE: 5.6 W
                            ICH:
                            ICH10: 4.5 W
                            ICH9: 4.0 W
                            ICH8: 4.1 W
                            ICH7: 3.3 W
                            ICH6: 3.8 W
                            ICH5: 2.4 W
                            ICH4: 2.2 W
                            - Dr Seuss
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              They missed 852 and 855.
                              I'll have to look those up later.
                              - Dr Seuss
                              • kiddznet
                                • Jul 2010
                                • 176
                                Thank you SEANC for that great picture
                                I will bung the caps n and see what happens.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Well I dunno PCBONEZ, I've got a Intel D945GCLF Mini-ITX mobo here
                                  It's got one of those Atom CPU's so the CPU is like 2 watts
                                  But they paired it with a 945GC chipset, according to the numbers you gave that should be ca 22w
                                  The chipset heatsink is like 4 times bigger than that of the CPU, and it has an active fan
                                  Which sounded like crap so I replaced it with a bigger copper heatsink and a very slow moving fan (I want this system dead silent, it is my firewall)
                                  The chipset still runs above 80°C with a copper heatsink and aircooling...
                                  Now you can argue the intelligence of Intels mainboard designers pairing a 2w CPU with a 22w Northbridge, but the fact still remains that that chip sure wont let itself be passively cooled (I tried, result was over 100°C and burnt finger when checking temps...)
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Many Laptop CPU's are more than 22 watts.
                                    http://ark.intel.com/Product.aspx?id=27593
                                    http://ark.intel.com/Product.aspx?id=27236
                                    How big are their fans?
                                    - Dr Seuss
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      seanc is that board in your photo a dead one? I wouldn't mind the bios chip if I can get some money to you for post to OZ?
                                      • seanc
                                        • Nov 2008
                                        • 1319
                                        It's only dead because 2 of the Nichion HM have blown - it does actually still POST and boot.
                                        BIOS chip is soldered on - not easily removable.
                                        I'd still expect yours to power on with a broken BIOS, just wouldn't expect it to do much.
