PS5 Controller BDM-010 CAP values
  • osbln
    • May 2024
    • 8
    When replacing the sticks, despite carefully taping the components, I probably tore off some capacitors. I suspect that the shrinking Capton tape tore them off.
    Can anyone tell me what values the capacitors in the picture have and what form factor they have?
    Thank you very much.
  • osbln
    • May 2024
    • 8
    I found out on another site that these capacitors should be 100nF and form factor 0201.
    • master3112
      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
      by master3112
      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
      10-29-2024, 09:32 PM
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
    • ronnygracias
      Help with freemotion incline trainer with controller comm error
      by ronnygracias
      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
      11-04-2024, 01:32 PM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
      Tankless hot water heater controller board not powering up when power is applied
      I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
      I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
      However I would like to know if I could figure what happened to this controller board if possible
      Tomorrow I will take some better pictures of both side of both boards
      The...
      12-09-2022, 09:14 PM
