Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Ethernet Controller 8S661FXM-RZ P4 and mssing cap values
    Originally posted by PCBONEZ
    Many Laptop CPU's are more than 22 watts.
    http://ark.intel.com/Product.aspx?id=27593
    http://ark.intel.com/Product.aspx?id=27236
    How big are their fans?
    I wont even argue
    I'll just let this picture speak for itself, CPU on the mobo edge, under the small heatsink, chipset under heatsink with fan, this is the mobo I own of which I also mentions how hot it runs, that is a 22w chipset
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I didn't say it wasn't built that way.
      I said it wasn't necessary to build it that way.
      Mann-Made Global Warming.
      - Dr Seuss
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        As I said I replaced the heatsink with a copper one, to try to passively cool the whole thing
        But it got over 100°C...
        So I had to put a fan on it in the end anyway. (But still much more silent than the original fan by Intel)
        This was the heatsink I bought for it; www.enzotechnology.com/cnb_r1.htm
        I also have a Asus Maximus Formula mainboard, with X38 chipset which is 26.5w according to your numbers
        This has one of those elaborate cooling heatsinks covering both chipsets and the CPU's power MOSFETs
        This thing also gets really hot, does not need forced air cooling but without it it gets up to around 75°C
        And I don't feel ok with that so I have some extra forced air blowing over it...
        Keeping it down at a cozy 50°C...
        What I'm trying to say is that these "recent" Intel chipsets wont be passively cooled, but sure some cooling from another fan, for example CPU fan blowing excess air over it, or case chassi fans providing airflow will let it run fine
        As you know in servers you generally have really smart air ducts, so no surprise there are no fans on the chipsets (which ironically are also super unreliable in mine and most everyone elses experience I know...)
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I can't see that heat-sink working so great without a fan on top because it blocks it's own air flow.
          One side is going to get air but the other side won't get nuthin'.
          Try one with fins [many thin vs a few thick] and align the fins such that they channel the air flow the full length of the heat-sink.
          Fins
          ----------------- <<-------- air flow
          - Dr Seuss
          • kiddznet
            • Jul 2010
            • 176
            On an Aussie site....
            Just fitted a fancy "no fan required" Zalman Northbridge cooler to my Asus A8N-SLI's nForce4 chip and the heat transfer is very efficient, so efficient that that darn thing is burning to the touch, and that is with 2 case fans blowing air over it from about 25cm away.
            I had to put a small fan on it because it got scary.
            The gold coloured Zalman heatsink looked brilliant on there, too bad it needs a fan on top covering it up
            These nForce4 chips are unbelievably hot items.
            Thing is, the motherboard temp is reporting 38*C when I know that heatsink must be close to 80*C.
            939 DualCore AMD Opteron, 1800 MHz (9 x 200)
            Abit AN8 / Fatal1ty AN8 SLI Series
            3072 MB (PC3200 DDR SDRAM)
            ATI Radeon HD 4300/4500 Series (1024 MB
            Lian LI Aluminium mesh case
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              You're right 100C is too hot. Max is 99C for that.
              Intel shows fins lined up as I described here:
              https://cdn.badcaps-static.com/pdfs/...8908b0d46a.pdf
              Also note that using it fan-less assumes a CPU fan is used.
              - Dr Seuss
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #27
                PCBONEZ; yea
                But this case has no fans
                As in it is a totally passively cooled chassis (well that was what I was aiming for anyway)
                I think you opinion of passive cooling differs from mine
                Passive in my world equals no fans
                It is a desktop chassi btw, so the fins point North, I think it is a decent enough layout, difficult to find good northbridge heatsinks, that fits the chassis and have a clip for mounting to the Northbridge
                Here is a picture of it, the first guy (or gal) to list all the mods done to this thing and explain how I took this picture will win a cookie of their choosing
                • kiddznet
                  • Jul 2010
                  • 176
                  #28
                  Ok. I buy a new fan....
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    PCBONEZ; yea
                    Passive in my world equals no fans.
                    Depends on where you apply the term passive.
                    1U & 2U servers have passive CPU coolers yet they have many fans.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      That's a cute little box.
                      I think I would put a lower RPM 80mm in the left side center [blowing in at chipset] and try without the chipset heat-sink, but that's just me.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        kiddznet
                        Put you location [at least country] in your profile so people know where you are.
                        It matters when suggesting parts sources.
                        Are you in the US?
                        - Dr Seuss
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          I would even try fitting a 120mm fan or so in there and cover the ram, nb and cpu all in one. But that kind of copper pin heatsink isn't good for having airflow coming down from the top (or about any direction for that matter). You might even have better luck flipping that little fan around so it pulls air through the pins.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Me too if the top is available for a fan.
                            If it's going to be on a desk that probably isn't a great idea.
                            - Dr Seuss
                            • kiddznet
                              • Jul 2010
                              • 176
                              #34
                              kiddznet
                              Right...fixed..
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Overseas shipping might kill the deal but sometimes this place is a good source for fans.
                                http://www.allelectronics.com/make-a...20/Fans/1.html
                                - Dr Seuss
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #36
                                  The sides of the chassis are not high enough for a 80mm fan, it is only 68mm high, so even a 60mm fan is a tight fit with the PCB taking up space etc...
                                  I did toy with the idea of LASER cutting a very nice looking airhole at the top and installing a fan there as you say, it of course defeats the purpose of a desktop chassis slightly, but I could live with that...
                                  This setup I use now is quite nice tho, it's also a good test for the capacitors in the Migrus C5 DC/DC PSU.
                                  (The originals hatched so where replaced with Samxons, that poor PSU runs extremely hot, fun to see how long they will last)
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    #37
                                    i am using d945gclf2 every day at work. dont really need much more power irfanview batch convert is not very fast though. would be nice to have a mini chassis.
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      #38
                                      Well... I replaced all the caps ...and... the little bugger doesnt even RUN now.
                                      I've checked everything I can I havent put any caps in backwards or left any out
                                      I got one twitch out of the CPU fan then NADA
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Short?
                                        • seanc
                                          • Nov 2008
                                          • 1319
                                          #40
                                          Short or bad joint. Check mosfets, they must be under those heatsinks...
                                          • briztech
                                            identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
                                            by briztech
                                            Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
                                            07-25-2024, 06:18 AM
                                          • master3112
                                            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                            by master3112
                                            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                            10-29-2024, 09:32 PM
                                          • proxneo
                                            Recapping Sony ICF-SW55 - verifying cap values
                                            by proxneo
                                            Dear reader
                                            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                            At the moment, I have selected replacements based on the following list of values:
                                            3 x 470uF 10VDC
                                            3 x 4.7uF 35VDC
                                            4 x 47uF 50VDC
                                            8 x 22uF 6.3 VDC
                                            1 x 220uF 6.3VDC
                                            5 x 100uF 6.3VDC
                                            Which...
                                            06-21-2023, 12:38 AM
                                          • Spikeman
                                            Dell Precision 3440 support for CPU 11th gen
                                            by Spikeman
                                            Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
                                            I ask you if it is possible to add the correct microcodes for the Precision 3440.
                                            I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
                                            Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
                                            03-11-2025, 09:54 AM
                                          • madan1
                                            Cisco catalyst 2960c POE
                                            by madan1
                                            Hello everyone.
                                            Got a catalyst 2960 from the usual scrapyard - ebay.
                                            It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                                            Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                                            Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                                            The switch fails to boot due to the following POST error:...
                                            12-19-2024, 09:34 AM
