Netgear switch dropping large packets.
  • Colt45ws
    • Jan 2009
    • 174
    I have a Netgear FS105 10/100 switch that will lose large packets that approach 1500 bytes. Initially I couldn't figure out why I was having trouble with (S)FTP dropping my connection or working really slowly. So I opened Ethereal or whatever they call that these days and saw the enormous amount of retransmissions. I opened a ping session with maximum packet size and lost 90%. Normal ping packets were fine. I removed it and attached my computer to the wall directly and no more trouble...
    Any ideas why it would do this? I opened it and the caps seem fine. None bulging or leaking.
  • kikkoman
    • Jul 2007
    • 691
    Re: Netgear switch dropping large packets.
    have you tried setting the MTU to 1492?
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • kaniki
      • 514
      also, have you tried different ports on the switch or different patch cables? Another possibility is that you are trying to use full duplex and maybe the switch only supports half duplex?? That could cause packet collisions which could give you the high loss rate too.
      I once had the same exact problem with my cable modem. they tried sending 15 meg speeds that the modem could only support 8 meg speeds. After upgrading from 8 to 15 megs, my download speeds went very irate and went from 8 meg down to more like 4 or 5 meg, even though they were pushing 15 megs though and the box was able to do 8 or so megs.
      • Colt45ws
        • Jan 2009
        • 174
        The loss was on any port with different cables. All had full duplex and always has been as far as I know. I didnt try forcing half duplex.
        It wasnt just max size packets, that just gave the most loss, so 1492 MTU wouldn't of helped much.
        • retiredcaps
          • Apr 2010
          • 9271
          The only time I have seen this is due to hardware error/failure. Most newer switches in the last 5 to 8 years have one asic controlling as many as 8 to 16 ports. If the asic is wonky, all ports will exhibit some sort of problem.
          You could try flashing with the latest firmware or reflashing if you already have the latest firmware in hopes of fixing it?
          Or you can look at the asic controlling the ethernet ports and check for bad/cold/dry solder joints?
          --- begin sig file ---
          --- end sig file ---
            • 31091
            what make are the caps?
            just coz they look fine means nothing.
            99% of the bad caps i'v removed during tv,video & satellite repair looked fine.
            • Colt45ws
              • Jan 2009
              • 174
              Teapo.
              With Capxon and a Jamicon in the brick.
                • 31091
                all shit.
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  i've got the same switch twice. 1 of them is currently in use on my main comp..
                  recapping them was the first thing i did, even though they seemed to work fine.
                  otherwise neat little 5port switch. especially with the thick all-metal casing.. no plastic crap
                  • Colt45ws
                    • Jan 2009
                    • 174
                    So you think new caps will fix it?
                    Thats why I like it, because its metal... Im going to upgrade to gigabit switches at some point, just need this to run a little longer. Right now Im using a WRT54G with everything disabled and the WAN port linked to the LAN ports. Powerful 5 port switch, basically. :P
                    Do you think Nichicon PW would be an acceptable replacement?
                    • AudioCraZ
                      • Sep 2009
                      • 147
                      One problem I have seen with several smaller Netgear switches is that they put a nice heatsink, but no air flow in the unit. With heat and a small space, that will destroy many cheap caps quickly. I ran a netgear switch for a while with it "open" so the heatsink cooled much better.
                      • ant3202
                        • Jun 2006
                        • 275
                        • Singapore
                        Teapo.
                        replace those shyt brands and see how.
                        I had this crap before with random reboots or hangs, caps looks fine, but once replaced, they were working great
                        • mattch
                          • Mar 2010
                          • 121
                          switch = layer 2
                          in other words that problem should be hardware related.
                          thats only true if your working fine without the switch (bypassing it)
                          beating a dead horse, 5/25
                            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 05:30 AM
                          • shovenose
                            Netgear JGS516PE Switch Fan Replacement
                            by shovenose
                            I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
                            It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
                            Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
                            I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
                            Instead of spending $30 on the correct replacement fan, does anyone have a clean...
                            12-12-2024, 03:24 PM
                          • Natob82
                            Micro Momentary Push Switch?
                            by Natob82
                            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                            12-21-2022, 05:22 AM
                          • grimacelord
                            NEC TurboExpress On/Off Power Switch Replacement Help
                            by grimacelord
                            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                            11-09-2023, 09:49 AM
                          • SluggerB
                            Help making a switch work the opposite way with a relay
                            by SluggerB
                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                            02-07-2025, 07:57 PM
