ubiquiti nano station M5 XM firmware dump
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Hello everyone. please someone can help me remove the username and password in a router ubiquiti nano station M5
    • 21186
    Re: ubiquiti nano station M5 XM firmware dump
    Here https://www.ui.com/download/airmax-m/nanostationm/nsm5
    Ask in this part of the forum for network gear . https://www.badcaps.net/forum/forumdisplay.php?f=36
    • Pascal Komlassan
      • Jan 2017
      • 809
      • TOGO
      Originally posted by SMDFlea
      Yes thank you for your help. But I downloaded this on their site for flashed and it did not work. only it comes back with its old interface but I forgot the password
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3608
        • slovakia
        u did not see that hole with mark "RESET" on it with switch in it???
        power up and hold switch for 20seconds. if still not reseted password than hold switch, add power and still hold switch for 20 seconds
        • Pascal Komlassan
          • Jan 2017
          • 809
          • TOGO
          okay thank you very much my brother. it is done
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3608
            • slovakia
            this method works for allmost every network and wifi equipment
            • the-sky-blue
              • Dec 2013
              • 48
              • salfeet
              try this
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • Tamo Neko
                Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                by Tamo Neko
                I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                What Happened:
                I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                What I Need:
                • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                02-12-2025, 11:29 PM
              • Mephysis
                DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                by Mephysis
                Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                03-27-2025, 02:34 AM
              • gun4as
                Need firmware dump for LG 23MP48HQ-P
                by gun4as
                Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                Yesterday, 04:28 AM
