Hello everyone. please someone can help me remove the username and password in a router ubiquiti nano station M5
ubiquiti nano station M5 XM firmware dump
Tags: None
Re: ubiquiti nano station M5 XM firmware dump
Here https://www.ui.com/download/airmax-m/nanostationm/nsm5
Ask in this part of the forum for network gear . https://www.badcaps.net/forum/forumdisplay.php?f=36 -
Ask in this part of the forum for network gear . https://www.badcaps.net/forum/forumdisplay.php?f=36Comment
u did not see that hole with mark "RESET" on it with switch in it???
power up and hold switch for 20seconds. if still not reseted password than hold switch, add power and still hold switch for 20 secondsComment
okay thank you very much my brother. it is doneComment
this method works for allmost every network and wifi equipmentComment
try thisAttached FilesLast edited by the-sky-blue; 02-09-2023, 04:45 AM.Comment
by AhariHi all,
I...-
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
- Loading...
