Cat5 Capabilities
  • Seagorman
    • Apr 2017
    • 70
    • Ireland
    Cat5 Capabilities
    Hi Guys, wondering if anyone can help me with the following issue, I'm on a 240mb Internet Connection, both my Router & Computer have Gigabyte ports but the maximum speed i can get is approximately 80mb at any one time, nothing else accessing the Internet during testing, i have a Cat5 cable connecting the PC direct to the Router, could this be the reason, will upgrading to Cat6 improve my speed? any help with this or any other suggestions would be most welcome, many thanks in advance.
    • 31087
    Re: Cat5 Capabilities
    network controllers have an internal loopback function for testing,
    i would find some software to make use of it.
    i would not be surprised if the speed limit was before the network controller.
    either the bus speed or your harddrive.
    • diif
      • Feb 2014
      • 6978
      • England
      You only need to upgrade to Cat5e cables to get gigabit speeds.
      Are all the ports on the router gigabit ?
      Cheeky neighbours on an unsecure network ?
      • Seagorman
        • Apr 2017
        • 70
        • Ireland
        will check out and see if i can find some software stj, tanx for that.
        diif, all the Router ports are gigabit, tried switching to different ports just in case one was faulty, network is very secured besides neighbours all on broadband also, tanx mate
        • jondoe
          • Nov 2016
          • 547
          You've mixed a few terms in your description, can you confirm your MB and Mbps? For instance, on a 1Gbps network connection the highest theoretical MB throughput is 125MB/s from machine to machine, etc.
          • aztekk
            • Dec 2015
            • 22
            Many ISP's advertise connection speeds as "up to" ie. maximum attainable value, and in practice the speeds tend to be lower than advertised, sometimes significantly, especially with high-speed connections such as yours. I'd first check what your modem reports as its current link speed.
            • Seagorman
              • Apr 2017
              • 70
              • Ireland
              Sry Johndoe meant Mbps, Tanx
              Tanx aztekk, ill check that out
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                Sounds to me like your devices are accessing the Internet over 10/100 ethernet and not gigabit.
                This is not a function of the cable you're using, as cat-5 ... especially at distances less than 200 meters ... will handle traffic pretty close to gigabit (1,000 megabits).
                The fact that you're only seeing 80 tells me that you're using 10/100 ethernet ports either on your router, or on your workstations.
                ANOTHER option is that the ISP has their end of your router incorrectly configured and that they are delivering you 200+ megabits of bandwidth over a 100 megaibit WAN port on your router ... ask them to test the service speed at your router to make sure you are getting the service you paid for delivered into your building and at your routing device ... if they can get the full 200+ of bandwidth, then start looking at how the ports are configured for the LAN side of your router and also on the devices you're using. If your devices are wireless then make sure they are using wireless technology that will support those speeds.
                every single device in the internet connection must be capable and configured to process data packets at speeds above what you're paying for ...
                Mike
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  By the way, this actually happened to me once the first time I bought a 300 megabit FIOS internet connection. I was getting less than 100 megabits but I knew immediately to check the 10/100 vs 10/100/1000 settings on my ethernet ports ... I was running gigabit so I called Verizon and asked them to look at the layer 2 side of my router and make sure it was configured for gigabit ... in my case, it turned out to be the fiber to copper bridge at the side of my house. It was still configured for 10/100 which was fine when I only had a 40 megabit connection ... but they upgraded my service without being thorough and checking the config on the CPE ... they got it changed within minutes to gigabit and BAM ... everything took off like a bolt of lightning ... never forget the first time I downloaded a 3 gigabyte torrent in less than 90 seconds ... a milestone for my life ... lol
                  sigpic
                  • Seagorman
                    • Apr 2017
                    • 70
                    • Ireland
                    Tanx EasyGoing1, ports are definitely Gigabit at both ends, i'm gonna ring my provider on Monday and see what they can come up with, many thanks for your suggestions, much appreciated
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Welcome, and please let us know what happens?
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        their tech support should be open 24/7 by the way...
                        sigpic
                        • Seagorman
                          • Apr 2017
                          • 70
                          • Ireland
                          Lol, its Ireland we're talking about here EasyGoing1, close at 2pm on a Saturday, off all day Sunday, i'll post an update tomorrow night , tanx again mate.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            If you're telling me that the work ethic in Ireland is to not work as often as possible, I might consider a move ;-) ... hows the pickins on good looking Irish women in the late 30s to mid 40s?
                            sigpic
                            • Seagorman
                              • Apr 2017
                              • 70
                              • Ireland
                              lol, a lazy lot us Irish, most of the 'Workers' have emigrated , plenty of women available in that age bracket, expect plenty of work to win them over though, they dont come easy (at least not the ones i know)
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                You mean they need a lot of convincing? Or they'll make me do stuff like ... fix the horse stables, re-tar the roof ... stuff like that ...???
                                sigpic
                                • Seagorman
                                  • Apr 2017
                                  • 70
                                  • Ireland
                                  Haa, haa, both unfortunately, steer clear & enjoy the easy life. Contacted my ISP today and was informed that my Router should have been upgraded last September when my package was upgraded, apparently my current Router is not Docsis 3 compatible, never bleedin heard of it but apparently the new one will solve all my issues, i'll reserve judgement until its up and running though, support guy seemed well clued in which is a surprise to say the least as i've been in contact 2-3 times before in relation to the same issue and the fuc*ers didnt have a clue, Router being delivered tomorrow so i'll update you with the good news (or not) tomorrow evening
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    DOCSIS 3 has only been out for ... 11 years ... nice of them to finally get on board and upgrade their network to the "NEW" standard... lol
                                    DOCSIS 3.1 is the newest latest and greatest standard and its been out less than two years...
                                    If you're curious ... all the info you'll probably ever want is right here:
                                    https://en.wikipedia.org/wiki/DOCSIS
                                    I'm sure it's going to fix your problem ... let me know.
                                    sigpic
                                    • Seagorman
                                      • Apr 2017
                                      • 70
                                      • Ireland
                                      Hi EasyGoing1, he quiet possibly could have said Docsis 3.1, either way i'd never bleedin heard of it, new Router installed, massive speed increase, registering a steady 228mps so well pleased with that, my porn library will increase with lightning speed now i can tell you, lol. Many thanks again for all your input, if you ever need fixing up with a strappin Irish girl let me know and i'll see what i can do for you
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        OH YES!!!! LET THE TORRENTS OVERFILL OUR HARD DRIVES-O-PLENTY!!!!
                                        So you got it like that with the Irish chicks, hu? That's pretty gangster!
                                        I've always been a sucker for redheads ... and yet I've only dated one and that was in high school ... odds of me being in Ireland in the foreseeable future? Slim to none ... but if it happens you'll be the first to know.
                                        sigpic
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • shadow666
                                          Router Xiaomi M4A Gigabit
                                          by shadow666
                                          hello
                                          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                          Mi Router 4A Gigabit Edition
                                          ROM CHIP is 16 MB
                                          i attached picture of motherboard​...
                                          11-30-2024, 03:49 PM
                                        • EasyGoing1
                                          UPNP, "Standards" and hardware that implements it
                                          by EasyGoing1
                                          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                          So I decided to implement UPNP...
                                          07-16-2022, 07:12 PM
                                          HDMI over CAT5 with a HDMI switcher for more than one computer being monitored proof
                                          I recently got a new shed that it my battery testing work bench beside this it also be electronic work bench as well and general work bench area as well
                                          I want to have a way to monitor more than one computer that is doing battery testing on the fly so I can switch between monitors and be able to see the results in real time
                                          I a chief engineer where I work gave me the information and idea to use a CAT5 repeater which would be the simplest way to do this
                                          They use a different method to transmit the data to tv monitors around the facility but that system requires...
                                          11-09-2023, 07:56 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
